headlights sometimes don't turn off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joshism, Apr 18, 2011.
  1. Apr 18, 2011 at 5:34 PM
    Joshism
    Joshism [OP] New Member
    Josh
    Florida
    I have a 2009 Tacoma automatic with no mods.
    Lately I've noticed a problem with the headlights not always automatically shutting off when I open the drivers door after turning off the ignition. Sometimes they turn off as soon as I open the door. Sometimes I have to close it and open it a second time. A several times I've had to open & shut the door 3 times. A few times its take 5 or more open-n-shuts, usually to the point where I give up and turn the lights off manually. I haven't been able to determine any pattern to when it turns off properly and when it doesn't.
    I'm still under warranty so I'll be taking it in to be checked this week. But I was curious to hear if anyone else has experienced a problem like this and what might be the cause.
  2. Apr 18, 2011 at 5:39 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    sounds like door switch may be sticking
  3. Apr 18, 2011 at 5:39 PM
    jivewalker
    jivewalker me gusta pechos firmes
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS
    2nd that^^^^ warranty
  4. Apr 18, 2011 at 6:23 PM
    005Tacoma
    005Tacoma Well-Known Member
    Macon Georgia
    2005 Toyota Tacoma
    x2
  5. Apr 18, 2011 at 6:30 PM
    Wayner275
    Wayner275 Member Me
    Regina, Saskatchewan
    09 Tacoma
    Step bars, Weathertech mats, Sirius sat., Fold-a-Cover G4 Elite, Pop-n-Lock (ditched the PopnLock and went with the Dyno Lock, RedLine hood struts, Cloud-rider Grill insert,
    It happened to me once on a super cold morning.
  6. Apr 18, 2011 at 6:33 PM
    pAP
    pAP ==========
    NJ
    11 Tacoma SR5
    ARB locker and OBA, All Pro front & rear bumper, All Pro IFS skid & modified t-case skid, Custom Trans Skid., 4x Innovations sliders, Custom tire carrier/bed bars, Warn Winch, Fox 2.5" Front coilover, Walker Evans 2.5" rear Shock, All pro Leaf, All Pro U-bolt flip, Baja Designs lights, PIA 510 lights, TRD exhaust cut back, Doug Thorley Pipe Bomb
    I also had this problem a few days ago. I had to close the door as well. I will check the the switch on the door. Glad it's not just me. :/)
    Pap
  7. Apr 18, 2011 at 6:50 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    same here, if you open the door and they stay on, give the door switch a wiggle and see if that solves it
  8. May 17, 2011 at 4:28 PM
    Joshism
    Josh
    Florida
    Followup on my original post: I noticed in addition to the headlights issue that the "door open" warning light on the dashboard was not lighting up and the "key in ignition" alarm was not sounding in the same instances where the headlights were turning off.
    The problem continued intermittently. I finally was able to get my Tacoma in to Toyota, where the service rep immediately diagnosed the issue as a problem with the "courtesy switch" in the driver's door. They did not have the part in stock so I had to come back again a week later after it arrived. It was of course covered by the warranty. Got it fixed today and hopefully that will be the end of the problem.
