Headlights stuck on
Discussion in '1st Gen. Tacomas (1995-2004)' started by fujifilmfan, Jan 16, 2023.
  1. Jan 16, 2023 at 5:22 PM
    fujifilmfan
    fujifilmfan [OP] New Member
    2004 Tacoma 4dr 3.4
    Hello all, my 2004 tacoma had the headlights stick on a few days ago. Read on here that a bad headlight relay could be the culprit. I changed the relay, jumpstarted the truck, and the issue seemed to be fixed. I then left it for a few days over the weekend. Just tried to start it again today and it was dead. Jumpstarted it and the headlights are sticking on again. I tapped the headlight relay with a wrench (read to do that on here) and the headlights are now functioning properly. Any reason as to why a new relay would be getting stuck and require tapping? some underlying problem that would be causing this? Thank you all in advance.
    -fujifilmfan
  2. Jan 17, 2023 at 2:53 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum!!
    No DRL`s??
    Did you test the relay you removed for function?
    It might be you have a more interesting problem.
    Poor Quality Relay !! Electrical/ Mechanical parts quality can be so hit or miss.
    The contacts might have been stuck.
    Unless something is grounding the coil side of the relay that would close the headlight circuit.
  3. Jan 17, 2023 at 8:28 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Most everything on these trucks are ground switching. Check the wiring harnesses for any nics or wear points where it might rub against the body.
