Headlights wont come on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shehates, Mar 5, 2023.
  1. Mar 5, 2023 at 9:14 AM
    Shehates
    Shehates [OP] Member
    Michael
    2018 sr5 4x4 Tacoma
    AMP PowerStep Electric Running Boards
    I have no hi or low beams. When checking at the lightbulb socket both wires are reading ground?
  2. Mar 5, 2023 at 9:19 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    any electrical modifications made at, or around, when this started? I would start there. Heck, if they are not current I would start there anyways and also check fuses.
    shakerhood likes this.
  3. Mar 5, 2023 at 9:29 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Strange to have no high or low. Start by checking the fuses, then the relays. After that it is possibly the switch. Relays or switch failure seems unlikely in a 2018 as that is pretty new.
  4. Mar 5, 2023 at 9:34 AM
    Shehates
    Michael
    2018 sr5 4x4 Tacoma
    All fuses good. When i start the truck the headlights flickered then would be fine. This lasted two weeks then i lost low beam headlights so i checked the fuses by pulling them out and push back in then tried it again and now i have no headlights?
  5. Mar 5, 2023 at 9:36 AM
    Shehates
    Michael
    2018 sr5 4x4 Tacoma
    The only modifications are
  6. Mar 5, 2023 at 9:38 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    it doesn't take much to upset the electrical systems on these trucks.
    are these motorized steps by chance tied to the headlight circuit? I would backtrack and look.
  7. Mar 5, 2023 at 9:39 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Try swapping one of the headlight fuses with a spare from the lid and see if it makes a difference.
  8. Mar 5, 2023 at 9:42 AM
    Shehates
    Michael
    2018 sr5 4x4 Tacoma
    Yes motorized
  9. Mar 5, 2023 at 9:45 AM
    Shehates
    Michael
    2018 sr5 4x4 Tacoma
    I’ll check to see if im tied into the headlights with my running boards
  10. Mar 5, 2023 at 9:48 AM
    Shehates
    Michael
    2018 sr5 4x4 Tacoma
    Stange because everything has been fine for8 months since thepower steps where put on
  11. Mar 5, 2023 at 9:49 AM
    Shehates
    Michael
    2018 sr5 4x4 Tacoma
    No difference from the fuse swap
  12. Mar 5, 2023 at 9:53 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Regarding brights, are you testing them with the auto high beams turned off?
    Very unlikely both, highs and lows, are not working. 2 separate fuses, 2 separate grounds. But still not impossible.
    crashnburn80 likes this.
  13. Mar 5, 2023 at 9:59 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Then go back to the relays. Turning off/on the headlights should cause an audible relay click, though clicking doesn’t necessarily mean they are working. But no click means that they are defective or not getting power. If so, pull the relay and see if you are getting 12v to the relay with your multimeter. If they do click, but you are not getting power to the headlights and the fuse is good, then it is likely a bad relay or something has damaged the wiring inbetween the relay and the headlights.
  14. Mar 5, 2023 at 9:59 AM
    caribe makaira
    Caribbean, Puerto Rico
    3 fuses for High and 3 fuses for Low...
    Looking at them isn't the correct method to check...:burp:
    eurowner, RustyGreen and jsinnard like this.
  15. Mar 5, 2023 at 10:12 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    given that its both sides and both high and low I would be looking a the control side of the system, possibilities:
    bad switch
    the way the steps were tied in damaged the control wiring and it finally broke
    rodent damage
