Headlights wont turn off - bad headlight switch, celica one fried it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by omegax, Nov 27, 2010.
  1. Nov 27, 2010 at 10:36 PM
    omegax
    omegax [OP] Member
    san diego
    99 A4 2.7
    So my left turn signal wasn't working and it wasn't the bulbs because they worked fine, and the right turn signal and headlights/high beams worked fine -
    So I went to the junkyard and found a turn signal arm off of a Celica (2000 model?) and it looked IDENTICAL to my Tacoma one -
    So I went home, installed it and upon doing so my headlights turned on and now they wont turn off - the blinkers work fine now - but I got no High-Beams either, and the headlights appear to be stuck in the High-Beam position yet No HIgh-Beam indication -
    I put my stock arm back in, and the headlights stay on:
    When I unplug the arm - the headlights turn off, soon as I plug in either the celica or stock tacoma arm the headlights come back on
    I tried to replace headlight relay and it did not change - headlights stay on
    All fuses are working fine
    Any suggestions? Should I just try an actual tacoma turn-signal arm? Thanks ! I hate to keep unplugging my turn signal arm just to fix this problem - and stock arm still dont turn left, but celica one does -
  2. Nov 27, 2010 at 10:58 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    id try to get a taco switch, call rancho used truck parts (google it)
    also check fuses
  3. Nov 28, 2010 at 7:58 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Did you disconnect the battery while plugging and playing? If not, it will reset the ecu and everything if you do. There might be a communication error.
