Headlights wont turn off
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98tacomagirl, Feb 16, 2014.
  1. Feb 16, 2014 at 10:32 PM
    98tacomagirl
    98tacomagirl [OP] Member
    Cassandra
    British Columbia, Canada
    1998 Toyota Tacoma 2.7l 4cyl
    I just bought this truck a week ago and so far everything has been great then all of a sudden my headlights and radio wont turn off even though the headlight switch isn't on.
    the dome light doesn't stay on, just the headlights and radio.
    everytime I turn my truck off I have to disconnect the battery so that it doesn't die.
    why is this happening and how do I fix it?
  2. Feb 16, 2014 at 10:37 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  3. Feb 16, 2014 at 10:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Did the truck have an alarm or remote start that you know of? Maybe look around under the dash for any wiring that looks botched. Good luck!
  4. Feb 16, 2014 at 10:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Are the headlights and radio tied into the same circuit? I doubt they are but I have to ask. It does sound like an ignition switch but it could also be a bad headlight switch as well if they are both tied into the same circuit indeed.
  5. Feb 16, 2014 at 11:08 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Start by checking all your fuses. It sounds like the lights and radio are getting constant power somehow.
  6. Feb 16, 2014 at 11:25 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
  7. Feb 17, 2014 at 7:02 AM
    98tacomagirl
    Cassandra
    Looks like im going to have to take it to a shop..
  8. Feb 17, 2014 at 7:07 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Shit. I was thinking the relay too. They DO stick sometimes.
    OP here is an easy thing to do. Just pop your hood pull your fuse cover and identity the headlight relay. Pull that one from it's home and then pull a similar relay by it (wiper relay or something accessory related that is non important at the moment) and put that relay in where the headlight relay originally was. If your lights now turn off upon removing the key then you know that one is the problem. You can easily find those relays at many auto parts stores if not the dealer for sure for a couple bucks.
  9. Feb 18, 2014 at 3:35 PM
    98tacomagirl
    Cassandra
    I took it to a shop and they said its because my windshield was leaking (it has a huge crack in it) and a lot of water leaked into the fuse box and corroded it so they completely took it apart and cleaned it and then covered it up. looks like I need to replace my windshield sooner than I wanted to. this is what happens when you live in Vancouver, BC, Canada.. way too much rain
