headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bearsdad, Dec 11, 2009.
  1. Dec 11, 2009 at 9:33 PM
    Bearsdad
    Bearsdad [OP] New Member
    rob
    So Cal
    basic
    Has anyone lost both low beams at the same time? I turned the truck off with both low beams on and working fine. After restart both do not work, all other light work correctly. Drove home with high beams. Thanks for any help.
  2. Dec 11, 2009 at 9:34 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    They could have just burned out... kinda bizare they'd both go out at exactly the same time but not impossible. Other than that, there could have been some kind of surge to blow out the low beam, or you have a loose connection or such for your lows.
  3. Dec 11, 2009 at 9:35 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    check the headlight fuses
  4. Dec 11, 2009 at 9:36 PM
    G-Sak
    G-Sak Well-Known Member
    PNW
    2005 TRD Offroad SR5 DC 6 speed
    FX-R Projector Retrofit with Apollo Shrouds, Digital HID 55 watt ballasts, D2S Philips 85122+ bulbs in the Winter and Digital HID 55w 5k bulbs in the summer, Bakflip G2, Pop N Lock, Tint, Grillcraft with PIAAs behind it, ScanguageII and a few audio/video upgrades.
    Did you check the fuses? Seems strange to lose both low beams at the same time.
  5. Dec 11, 2009 at 9:50 PM
    Bearsdad
    rob
    So Cal
    basic
    Thanks for the reminder to check the simple stuff first (fuses).
  6. Dec 11, 2009 at 9:56 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    it could also be the relays they are in the main fuse box under the hood
  7. Dec 12, 2009 at 5:20 PM
    Bearsdad
    rob
    So Cal
    basic
    Fuses are good. High beams/running lights work fine. Do high and low beams use seperate relays and or is there a seprate control? I have not checked the lights themself yet (as it is actually raining in So Cal.) and I find it hard to believe both would go out at the same exact time. Both worked fine when I left the TACO and neither worked when I returned in about an hour. Also both were replaced about three months ago. Thanks again for any help or info.
  8. Dec 13, 2009 at 8:14 PM
    rhodehard09
    tampa, fl
    there are separate relays for high and low a quik check would be to take the high beam relay and plug it into the low beam spot
