Headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by KSP, Feb 16, 2024.
  1. Feb 16, 2024 at 11:37 AM
    KSP
    KSP [OP] New Member
    Ken
    04 Tacoma
    I know this horse has bean beaten 1000 times but maybe there's something I don't know. I'm tired of the the headlights oxidizing (getting dull) and as far as I know, there's no glass ones and I don't really feel like paying 200.00 a piece or so for the Toy ones. Are there any good aftermarket ones that are less expensive and hopefully as good or better than the OEM ones? The brightness of the stock bulbs are OK for my purposes.
    Thanks Ken 2004 Tacoma.
  2. Feb 16, 2024 at 11:45 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I got 15 years out of the ones on my 07 before they got so bad I had to replace them. It was a hard pill to swallow, but I went back to factory. Toyota wanted $750 for a set for my truck. Aftermarket would have been $250-$300 but I got so many negative reviews that I had a hard time with those.
    One of my wife's brothers owns a local body shop and on a whim, I asked him to inquire about buying a set. The same headlight assemblies Toyota wanted me to pay $750 for were delivered to his shop for $550. Literally the same boxes from the same dealer. I paid him the $550 and installed them.
    To be honest I wouldn't have paid $750. I'd have taken my chances on aftermarket. They wouldn't last as long,but at 1/3 the price I could afford to replace them sooner. But for $550 I did it. If you know someone with a commercial account you may be able to get them to get them for you at a reduced price too.
  3. Feb 16, 2024 at 11:51 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    in short, no
  4. Feb 16, 2024 at 12:31 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Applying a ceramic coating to your headlights will prevent oxidizing.
  5. Feb 16, 2024 at 1:12 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I've restored many headlights in the past to new but it requires a bit of work and spraying a high quality clear coat that has isocyanates in it. A respirator is an absolute must but a fresh air sysem is evem better. It will last as long as the clearcoat on automotive paint. You need to sand going up from 600 grit to 1500 in stages and then spraying the clear then sanding again with 2000 or higher then polishing.
  6. Feb 16, 2024 at 5:03 PM
    KSP
    KSP [OP] New Member
    Ken
    04 Tacoma
    Where do you get the ceramic coating?
  7. Feb 16, 2024 at 5:58 PM
    foresterfields40
    foresterfields40 Well-Known Member
    ‘99 Tacoma 3.4 4x4
  8. Feb 16, 2024 at 8:51 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    There are ‘professional’ HL restore vendors
    Used many times(ins work)
    For example
    $1500 BMW HL had a dent on edge of plastic lens…customer hit their garage door….the roller track (huge L shaped track) the HL was not cracked but had 3mm dent and scratches on lens
    $125 + 25% mark up for shop
    I couldn’t believe how well it turned out
    search headlamp restoration in your area
    the vendor here in Houston is called Headlamp Doctor
    Pm me if anyone wants contact info
