Headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ascotta05, Jun 8, 2025.
  1. Jun 8, 2025 at 2:55 PM
    Ascotta05
    Ascotta05 [OP] Well-Known Member
    NC
    Does anyone know for sure that headlights from 22 sr5
    will fit an 18sr?
  2. Jun 8, 2025 at 3:00 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Yes
    All 3rd gen housings are compatible in fit, regardless of year, and you only need to worry about a full wiring conversion harnesses when going from halogen assemblies to LED (or vice versa).
    Make sure the “new” assemblies match your truck in terms of DRLs though. The OEM halogen headlights come with either LED or Halogen DRLs
    Chew and soundman98 like this.
  3. Jun 8, 2025 at 6:00 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Yes, fitup is the same. Only concern is if you are replacing the halogen lamp assembly with the oem LED headlamp, in which case you'll need a conversion harness.
  4. Jun 8, 2025 at 7:53 PM
    itsnotatoy
    itsnotatoy Well-Known Member
    NW Valley AZ
    2023 Tacoma DCSB ICE CAP TRD Sport Premium & Tech Pkg
    Puppypunter likes this.
  5. Jun 8, 2025 at 8:03 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    They will, no harness needed assuming neither truck has been modified.
    There are three types of headlights as pointed out by @musicisevil
    1) Halogens SR/SR5/trailhunter. These use a halogen DRL, which is a shared bulb with the turn signal. So it is amber unless changed to a switchback or something.
    2) Halogen TRD trims. These have an LED DRL they is “L” shaped around the low beam.
    3) OEM LEDs. These are full LED, and have a “C” shaped DRL that goes around the low and high beam. The DRL is white, with a switchback amber turn signal. The turn signal is also reverse sequential.
    So as long as you are swapping like for like (like a #1 for a #1 in your case), no conversion is needed. Going from one number to a different number will require a harness though. And depending on which number to which number, that harness can be pretty simple or fairly complex. But all are doable.
    itsnotatoy and musicisevil like this.
