Headliner Removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Aug 18, 2010.
  1. Aug 18, 2010 at 12:41 PM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    06 Double-Cab TRD Sport 6-Speed
    I'm trying to remove the headliner in my double cab.
    Would "headliner" be the correct term to search? It seems as if there aren't many write ups on how to do this.
    If anybody knows how to do it, could they explain?
  2. Aug 18, 2010 at 12:52 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Just clarifying that you mean the carpet on the ceiling, right?
  3. Aug 18, 2010 at 12:55 PM
    BarefootBandit
    Yep the ceiling carpet. I'm installing a NMO GPS antenna.
  4. Aug 18, 2010 at 4:36 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    I believe you need to remove all the plastic trim pieces that meet up with headliner, because there are usually little push pins underneath them. Take out the done light(s), overhead compass, and there are two more push pins toward the center of the liner. If it stare at it for a bit, i'm sure you can figure it out.
    yup.... plastic panels all need to come off.
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/064003.pdf
