Headliner removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DaveEli, Feb 11, 2013.
  1. Feb 11, 2013 at 3:04 PM
    DaveEli
    DaveEli [OP] Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    I am getting ready to remove my headliner from my 2011 Access Cab. What do I need to be careful of? I am concerened about the 4 plastic covers that say SRS Curtain Airbag on them. What is behind those covers? What holds the headliner on the sides of the cab?
  2. Feb 11, 2013 at 9:31 PM
    devenob
    devenob Well-Known Member
    Deven
    MA
    ‘16 TRD SPRT DCLB
    TRD Exhuast tip Various vinyl inlays Nerf bars TRD PRO Grill De badged TRD Pro tail lights
    bump i am wondering this to
  3. Feb 11, 2013 at 10:22 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    i'm not sure how sensitive they are but messing with air bags freaks me out lol. probably just need to disconnect the battery and should be good to go.
    :popcorn:
  4. Feb 11, 2013 at 10:36 PM
    BMOC
    Paden
    Phoenix, AZ
  5. Feb 12, 2013 at 4:27 AM
    DaveEli
    David
    Virginia Beach
    I watched those videos before. His little plastic covers did not say SRS curtain airbags on them making me think he doesn't have air bags there. I am afraid to pop those covers. Are there air bags there?
  6. Feb 12, 2013 at 4:32 AM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    Your side curtain air bags are behind there I work at a body shop and change and work around air bags all day. Just unplug your battery and you will be fine they wont deploy from just taking that panel off.
  7. Feb 12, 2013 at 4:54 AM
    DaveEli
    David
    Virginia Beach
    Thanks. To be clear do I take those covers off? What holds the headliner in place there?
  8. Feb 12, 2013 at 8:12 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    Those little plastic covers are just bolts to hold the headliner up. They also serve to redirect the airbag down along the window. The airbags aren't in them. Just open them up and unbolt them.
    The airbag itself runs as a long tube from the rear, up along the upper door frame, down the A-pillar. You shouldn't run into any trouble with it.
    There are some pics in my gallery, and this DC headliner post is pretty much the same as the AC.
  9. Feb 12, 2013 at 9:41 AM
    DaveEli
    David
    Virginia Beach
    Thanks that is exactly what I need to know. Your write up is great.
