Headstrong front lift coils?
Discussion in 'Suspension' started by Apex1, Dec 2, 2018.
  1. Dec 8, 2018 at 9:44 AM
    Teamnoble11
    Teamnoble11 Active Member
    Nick
    2011 Tacoma TRD sport
    They aligned great! And my truck tracks excellent. 0 toe, 0 camber, 3.5 degrees of caster. Best part is they were $320! Have greaseable zerks on the ball joint along with some great customer service. Already hit them up for an extra pair of top caps and some new decals. I paid for them, just wanted an extra pair.
  2. Dec 8, 2018 at 10:30 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    How long have you had them on? Do you press in a stock ball joint when on goes bad? I may pick up a set next ebay 15% off coupon.
  3. Dec 8, 2018 at 10:38 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    @ChadsPride how is the ride? Assuming you are on the first notch? I have 5100’s with sport springs at 1.75 notch and its stiff as hell, even harsh on highway bumps.
    ChadsPride[QUOTED] likes this.
  4. Dec 8, 2018 at 12:25 PM
    Teamnoble11
    Nick
    From what I’ve read. Yes, the ball joint can be pressed in. Fairly simple process if one goes bad.
  5. Dec 9, 2018 at 12:14 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Rides great, very happy with them.
  6. Dec 9, 2018 at 1:48 PM
    hyper15125
    NJ (609)
    Thanks!
  7. Jan 11, 2019 at 10:00 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    I had the HS coils and 5100s installed during my frame replacement last spring along with Deaver AALs for the stock springs in the rear. Truck sits level and rides pretty well for the terrible roads up here.
    After the lift I did notice that the truck rocks back and forth more, such as the front end lifting up a bit when you take off from a stop, and then diving more when you hit the brakes, but I guess that's common with any lift due to the extra suspension travel. Maybe heavier springs in the front would reduce that.
    The only thing I haven't been able to figure out is a clunking noise from the front end that occurs when you take off from a stop. I've checked everything over and I didn't find loose bolts or parts hitting each other so I've learned to ignore it.
  8. Jan 11, 2019 at 10:52 AM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    I have had the HS coils paired with 5100s for the last 8 months or so. No issues at all.
  9. Jan 11, 2019 at 11:59 AM
    hyper15125
    NJ (609)
    Concerning the clunking noise, low brake pads that needs replacing have been known to cause similar sounds. I had this issue and new pads and the double spring mod eliminated the noise.DABF81FD-E828-4BE8-8823-E8E5103C8970.jpg
    boostedka likes this.
  10. Jan 11, 2019 at 6:45 PM
    JMGARCIA31
    JMGARCIA31 Well-Known Member
    Luis
    Jacksonville, NC
    2015 silver trd offroad dcsb 4x4 auto
    5100's @2.5 and add a leaf. 255/80R17 Cooper ST Maxx.
    Do you have the stock uca or aftermarket? Because it could also be coming from the stock ones after being maxed out.
  11. Jan 12, 2019 at 5:20 AM
    Apex1
    Apex1 [OP] Well-Known Member
    Central CT
    2011 DCSB TRD
    What are the limitations of the stock UCAs with a lift? Is it caster, camber or both? Or is it a travel issue?
  12. Jan 12, 2019 at 11:31 AM
    JMGARCIA31
    Luis
    Jacksonville, NC
    Caster is the main one.
  13. Jan 13, 2019 at 4:59 AM
    Apex1
    Central CT
    2011 DCSB TRD
    Makes sense, what is a good caster number? +3 degrees?
  14. Jan 14, 2019 at 9:02 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    1 degree for each inch of lift.
  15. Jan 16, 2019 at 8:34 AM
    #35
    nh_yota
    Jeff
    Portsmouth, NH
    Stock, figured they were okay for a 2" lift.
  16. Jan 16, 2019 at 8:35 AM
    #36
    nh_yota
    Jeff
    Portsmouth, NH
    Yeah I'm familiar with that sound and it's not the one I hear. I replaced the front brakes in 2017. The brake sound is more of a click than a clunk.
  17. Jan 16, 2019 at 8:37 AM
    #37
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Thanks for posting that. That is a great idea. I just did that to mine two nights ago after seeing your post.
    hyper15125[QUOTED] likes this.
  18. Jan 16, 2019 at 8:56 AM
    #38
    hyper15125
    NJ (609)
    :thumbsup:
    I got from another member so I cant take credit but is worth passing on.
    boostedka[QUOTED] likes this.
  19. Jan 16, 2019 at 5:21 PM
    #39
    JMGARCIA31
    Luis
    Jacksonville, NC
    I have about 2.5 and mines are maxed out. Have you gotten an alignment since your lift?
  20. Jan 17, 2019 at 12:05 PM
    #40
    nh_yota
    Jeff
    Portsmouth, NH
    Yes it was aligned after it was installed and then again six months later.
