Headstrong kit, Coil/Bilstein 5100 lift Kit question
Discussion in 'HeadStrong Off-Road' started by mms, Dec 6, 2015.
  1. Oct 1, 2018 at 12:02 PM
    #161
    hoytrules
    hoytrules Member
    2010 tacoma double cab longbed
    I'm thinking of doing the same as post # 13 and was wondering if you could help. I have a 2010 dclb with topper I have had new springs Installed in the rear. Thanks
  2. Oct 1, 2018 at 10:25 PM
    #162
    thunderhope
    thunderhope Well-Known Member
    2019 Tacoma OffRoad 4x4
    did that setup clear 285/75/16 tires? looking to do the same
  3. Oct 7, 2018 at 7:43 AM
    #163
    burddog
    burddog Active Member
    Ephrata, PA
    2015 prerunner
    American Outlaw Hollywood 17x8.5 -10 offset Bilsein 5100 all around Low Range 1" rear Blocks Hankook Dynapro atm 265/70/17 Shaved badges A little rattle can green on the front. Gator soft bed cover
    Hello,
    I have a 2015 DCSB Prerunner. It's never offroad, I just want a nice level stance. I was about to order bilstein 5100 to set at 1.75 and leave the back alone. Then I started looking at your 2 inch coils. My question is... being a prerunner and a 4cyl double cab, would I be higher that 2 inches due to lack of weight or does the double cab keep it level?
    If the springs push it higher I dont mind a 1 inch block in back. I just dont want the "taco lean".
    Yes. They make DCSB 4cyl. Prerunners... everyone's a prerunner in 2wd.
    09 Redneck likes this.
  4. Oct 11, 2018 at 4:23 PM
    #164
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    ordered set of bilsteins shocks like yesterday and got them today, what fast service that was, (Thank You for the fast service) one question I have is that there is two large washer in the bag that I cannot figure out where they go, anyone have a answer for that. I have a 2017 Tacoma TRD Sport Thanks
  5. Oct 19, 2018 at 6:45 PM
    #165
    Ronnie1990
    Ronnie1990 Member
    Virginia
    2016 SR 4x4
    Nothing Yet
    Hey Headstrong Offroad i have a 2016 Double cab SR 4x4. What size coil would be best with a AAL to level truck out. Dont mind slight rake just dont want the bro lean. Planning to order 265/75/16 tires. I know they will fit stock just want a little more clearance
  6. Oct 28, 2018 at 6:54 PM
    #166
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    I too have questions about those washers. I left them out. Just remembered that dealership replaced my springs because defective, from two leafs to three.
    I have a Monroe quick strut in front,
    What should I expect my total lift to be , front and back?
    I measured 20” front center of front to fender and 22” in rear both sides
  7. Dec 6, 2018 at 4:00 PM
    #167
    C5ENA
    C5ENA New Member
    White TRD off road 2018
    Have a 2018 TRD off-road after reading I think I’m sold on Bilstein curious to what setup I would need to go with front and back for 2”-2.5 inch lift while maintaining the best ride for every day driving maybe a weekend every once in a while off-road thanks in advance
  8. Dec 29, 2018 at 6:23 PM
    #168
    Spackletooms
    Spackletooms Well-Known Member
    BC, Canada
    Does the full 5100 bilstein kit include longer rear brake lines and CB drop kit?
  9. Jan 1, 2019 at 4:17 PM
    #169
    C5ENA
    C5ENA New Member
    I’m pretty sure it doesn’t but could be wrong
  10. Jan 6, 2019 at 7:07 PM
    #170
    Inkedgenius85
    Inkedgenius85 Well-Known Member
    Danny
    Turner, OR
    2014 MGM TRD Sport DCLB
    17x8 Vision Raptors Falken Wild Peak 265/65/17 20% tint DeeZee bed mat Center console holster Alla lighting 3000k led fog light bulbs Alla LED license plate bulbs JDM Astar led reverse light bulbs Bilstein 5100s all around 1/4" Taco spacer HeadStrong 2" lift coils HeadStrong Progressive AAL
    I have a question that I can't seem to find an answer to after scouring the forums forever today... At least the thread name matches my search.
    I have the HS 2" lift coils that I'm putting on new Bilstein 5100's with the HS strut mount kit.. I'm doing this on my own with a spring compressor that I rented from AutoZone.
    My question is:
    Is there a certain orientation that the spring seat/coil/top hat need to be in relation to one another?
    I'd like to get this part figured out before I go to mount them, only to find that they don't line up.
  11. Mar 6, 2019 at 2:44 PM
    #171
    tim allan
    tim allan Well-Known Member
    Wv
    2017 double cab trd offroad
    can you send me a price for a 3rd gen please?
  12. Apr 11, 2022 at 12:57 PM
    #172
    kody344
    kody344 Member
    2021 SR5
    Could you PM me? I have a few questions, and was looking at a kit on your site. Thank you!
  13. Apr 13, 2022 at 8:17 PM
    #173
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    PM sent but not sure if you got it. You can email us as well. Thanks :)
