Headstrong kit with progressive leafs... thoughts?
Discussion in 'Suspension' started by jstyle, Apr 8, 2018.
  1. Apr 8, 2018 at 5:45 AM
    jstyle
    jstyle [OP] Well-Known Member
    Josh
    2012 Taco Off Road
    Anything that was shiny is now black
  2. Apr 8, 2018 at 9:57 AM
    Taco Gusto
    Taco Gusto Member
    Calgary, Ab
    2017 TRD Sport 4x4 DCSB
    After doing a fair amount of research, both reading here and talking to guys at local shops, I'm having this kit installed on Thursday. The only difference would be an Icon 3 leaf AAL in place of the HS. My understanding is that Deaver is making most of these leaf packs for the usual suspects so it's probably the same thing you'd be getting with the HS AAL. My goal is ~2" up front with the 887 springs and ~1-1/2" in the rear with the factory overload removed. If I'm not mistaken, these numbers would be different for your application because 2nd gen. I'll report back with my experience. I'm sure others who have already gone this route will chime in before then.
    FWIW, I had the same kit on my last truck, not a Tacoma, with the full Dakar pack and it was perfect for my needs. Mostly on-road with the need for a little more hauling capacity and some off-road use. It was great and I had zero issues with any of the components for the four years I used it before I got the new truck.
  3. Apr 8, 2018 at 10:05 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    The front will depend on which spring you pick and the weight. If you have armor vs stock you'll want a heavier spring to get height.
    The rear aal is 1.5-2 inches depending on removing or leaving in the overload leaf.
    Hit up @HeadStrong Off-Road direct if you need their front end recommendation.
    Here's my suspension install vlog where I'm using their AAL.
    https://youtu.be/9mdo-GnoVhY
  4. Apr 8, 2018 at 10:44 AM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    Looked into this kit, its discontinued? Anyone know where you can purchase it?
    I posted the discontinues reply in your Youtube channel.... not sure why when I should have done it here....:crapstorm:
  5. Apr 8, 2018 at 2:15 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    Yep
    There were 2 big threads here about it.
  6. Apr 8, 2018 at 8:20 PM
    Scamilton
    Scamilton Nerf Herder
    J
    Colorado
    2017 TRD OR DCSB Blazin' Blue Pearl
    BAMF recessed grille, tailgate inserts, windows tinted, matte black vinyl on rocker panels, badge removal, Fox front 2.5 with resi, Fox 2.0 with resi rear, LR UCAs, matte gunmetal Black Rhino Warlord, 33"x12.5" Mickey Thompson Baja Boss, rigid ditch lights, Sherpa Grand Teton roof rack.
    Dude... Just did my (fox) suspension today. First off, what a pain in the ass. Second, didn't know I was going to need to cut off part of my factory leafs so the HS 3 leaf would fit. So, I've got the bro lean going. Either way, your video will be super helpful when we finish her up and do the leaf packs next weekend.
    Rob Daman[QUOTED] likes this.
  7. Apr 8, 2018 at 8:41 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    Fox sounds like an awesome ride.
    Yea I've learned the hard way over the years that the term "bolt on" doesn't mean "easy on." :rofl:
    Glad I can help reduce some of the pain when DIYing. :thumbsup:
  8. Apr 8, 2018 at 8:45 PM
    Scamilton
    J
    Colorado
    Man, being bent over all day and on my knees on concrete I am whooped. I'm in good shape, but I'm definitely feeling all 32 years of age today.
    It was a learning experience for sure. I learned new ways to be full of anger and stress lol
    Rob Daman likes this.
  9. Apr 10, 2018 at 6:23 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @Rob Daman for your recommendation :)
