Heard you can have a lot of problems lifting the truck
Discussion in 'Suspension' started by BigHoss, Mar 13, 2013.
  1. Mar 13, 2013 at 6:50 AM
    BigHoss
    BigHoss [OP] Member
    Jake
    Omaha Ne
    06 TRD Sport
    I have debated whether or not to lift my 06 crew sport I would do nothing bigger than a 3 inch lift but I heard it can be really hard on the truck. What lift would recommend? Would I need all new suspension?
  2. Mar 13, 2013 at 6:57 AM
    Large
    Large Red
    Front coils / shocks, rear leaf pack or add a leaf or blocks. If you lift the front higher than 2.5" it's a hit or miss that you will need new UCAs to get alignment in specs, that means if you think you'll be fine go for it, if the caster is out of spec you'll need new UCAs. There are lots of good vendors on the site for suspension components, check Toytec and downsouthmotorsports
  3. Mar 13, 2013 at 7:05 AM
    medic2230
    Murph
    Bama! Roll Tide
    I've had my full 3" OME lift on for almost a year with LR UCA's and haven't had one problem out of it. The truck actually handles better than stock.
  4. Mar 13, 2013 at 7:11 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Just don't go with the chespest lift and if you do it just do it right
  5. Mar 13, 2013 at 7:16 AM
    BigHoss
    BigHoss [OP] Member
    Jake
    Omaha Ne
    06 TRD Sport
    My buddy has a RC 5 inch on his tundra and he loves it what do you think about a RC 2.5 or 3 in heard any rumors?
  6. Mar 13, 2013 at 7:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you're referring to the Rough Country 3" lift, I wouldn't touch it. That kit uses lifting blocks for the rear and top plate spacers for the front. I would recommend getting your lift from either a replacement leaf pack or an AAL for the rear and lift coils for the front. Spacers and blocks can cause the truck to ride like crap and has the potential to cause damage to your truck.
  7. Mar 13, 2013 at 9:05 AM
    BORNWILDGUY
    Rich
    Florida
    bilstein 5100's set at .85, ebiach springs, progressive 3 leaf pack for rear w bilstein 5100's as well
  8. Mar 13, 2013 at 9:12 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Welcome to TW Jake,
    here is a link that has a lot of lift resources and such.
    http://www.tacomaworld.com/forum/suspension/
