hearing a chirp when i ht a bump in my truck
Discussion in '4 Cylinder' started by killzone90, Jan 22, 2011.
  1. Jan 22, 2011 at 1:55 PM
    killzone90
    killzone90 [OP] Well-Known Member
    Ethan
    Fairdale,ky
    96 tacoma
    Im hearing a chirp when i hit a bump.it kinda sounds like a window.what might it be
  2. Jan 22, 2011 at 2:01 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    might be a window
  3. Jan 23, 2011 at 12:56 PM
    killzone90
    Ethan
    Fairdale,ky
    96 tacoma
    yea when i hit bumps i hear it.
  4. Feb 25, 2011 at 10:15 AM
    hunterjody
    hunterjody Member
    Jody
    00 Tacoma 2wd SR5 ex cab
    I had a similar problem years ago with my 2000 2wd ex cab and the dealer couldn't figure it out either. It would only show up when I was carrying a passenger and I hit a small bump. Turned out that it was the heat shield above the catalytic converter rubbing the bottom of the body. All I did was bend the heat shield back away from the body and it's been fine since.
