Heat/AC Routing too low in driver footwell, potentially unsafe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by imageomega, Jan 8, 2016.
  1. Jan 8, 2016 at 5:51 AM
    imageomega
    imageomega [OP] Well-Known Member
    Jarrod
    Not sure if any one else feels this way, but I found this to be a serious issue so wanted to share.
    I often wear boots/safety shoes with large soles for work, and very shortly after purchasing the Tacoma I nearly had an accident because the drivers foot well venting comes so low/near to the pedals. (The toe of my boot caught the venting and the pressure I was applying did not get to the brake pedal... it was a close call)
    So I quickly removed the culprit. This pic is not from a Tacoma but gets the point across. The splitter (I believe to make the air flow to "both feet") unclips from the rest of the vent, and gives you 4-6" more clearance for your driving foot. I feel much better about it. No difference in heat/AC feel when using the lower settings.
    Maybe it helps someone else... be careful out there!
    shr133 likes this.
  2. Jan 8, 2016 at 6:11 AM
    Pigpen
    Dan
    Northwest Montana
    There's a lever on the lower part of the front of your seat than could also help with this "problem".
    When I wear my heavy work boots while driving, I use this lever and the problem goes away.
  3. Jan 8, 2016 at 6:14 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    The pic is not of a Tacoma, so it does NOT get the point across.
    YotaDriver631 and 127.0.0.1 like this.
  4. Jan 8, 2016 at 6:27 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    OP I know what you mean. When I wear snow boots, it can get pretty cramped in that footwell.
    I guess that's just how it is on mid size trucks...
  5. Jan 8, 2016 at 6:34 AM
    imageomega
    Jarrod
    ...my legs nor arms get longer when I wear larger boots... but I'm glad it works for you.
  6. Jan 8, 2016 at 6:47 AM
    imageomega
    Jarrod
    Ok...Diagram of my 2013's HVAC routing. Part # 87230 extends down towards the pedals in the driver foot well. For me, it extended too close and at one time interfered with proper braking. I would often be whacking it with the toe, even when it wasn't interfering.
  7. Jan 8, 2016 at 6:50 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    And so this part pops off? Looks like a plastic rivet 87201k is holding it in place?
    Rusty1606 likes this.
  8. Jan 8, 2016 at 6:55 AM
    imageomega
    Jarrod
    Its one of those interior pop clips. It could be reinstalled easily if desired.
    Clip is similar to;
  9. Jan 8, 2016 at 7:21 AM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I can drive my truck in ski boots with no interference. ..you must have some serious clown feet...
  10. Jan 8, 2016 at 7:25 AM
    imageomega
    Jarrod
    Surely it may be the way I sit/angle at the pedals. I realize its not a problem for most.
  11. Jan 8, 2016 at 7:42 AM
    Pigpen
    Dan
    Northwest Montana
    This guy thought he could drive in ski boots, too
    Josh828 likes this.
  12. Jan 8, 2016 at 7:44 AM
    imageomega
    Jarrod
    ^^ that is precisely what I was afraid of, and why I shared my experience.
    Especially in an emergency situation where you lift your foot to hit the pedal harder than normal....
  13. Jan 8, 2016 at 8:18 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  14. Jan 8, 2016 at 8:22 AM
    CO Ryan
    CO Ryan Well-Known Member
    Colorado
    13 TRD Offroad
    stuff
    That parts diagram looks like a Star Wars character. Can someone please recreate it with no part numbers and all parts connected? Thanks.
  15. Jan 8, 2016 at 8:23 AM
    tacoma4
    tacoma4 Well-Known Member
    I had this problem when wearing my steel toes. Pretty sketchy when trying to go from gas to brake quickly. I took off that same extension piece in the diagram above and tossed it in the glove box. No problems since
  16. Jan 8, 2016 at 8:27 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I removed the lower section of that heat vent , it just unclips , I posted a pic in another thread about this same thing , takes 30 seconds
    EDIT : Part # 87230 from above diagram
  17. Jan 8, 2016 at 8:36 AM
    taczilla
    Marc
    2016 RAM Rebel
    I just went and checked mine. That part is up and under the lower dash panel in my 2012. I would have to kick up and back to even come close to it.
  18. Jan 8, 2016 at 8:41 AM
    imageomega
    Jarrod
    Ill pop it back on and get a picture later. Not sure of the distances as I did this about a week ago, but it was quite close to the top of the brake.
  19. Jan 8, 2016 at 8:42 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I've worn 2 different pair of metatarsal boots never had this issue. Now watch me after reading this have this issue. Just curious op but what size are your boots. My foot definitely doesn't ride that far up the gas pedal. I have neither large feet or long arms. Sooooo idk hahah
  20. Jan 8, 2016 at 8:45 AM
    imageomega
    Jarrod
    I'm not a huge guy; 5'9" and size 10 or 11 by brand. These steel toe boots are where I had the biggest issue. The lip is at least a full half inch, which contributed to my perception of how close the duct was.
