Heat and performance. Myth or fact?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djgynee, Jun 15, 2021.
  1. Jun 16, 2021 at 10:37 AM
    #61
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You should look into the development of the P-38.
    FastEddy59 and MOC221_[QUOTED] like this.
  2. Jun 16, 2021 at 10:48 AM
    #62
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    So like this. ^^
  3. Jun 16, 2021 at 11:03 AM
    #63
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    What is going on here? Ok so theories about power and operating temperature not based on the Internet, here we go.
    Cold air is more dense, more O2 per volume -> more fuel can be added before hitting fuel air ratio limits.
    - once engine/transition is warmed up the parasitic friction loses are similar to any other ambient temperature
    - if you are talking about power from a stop or at low speeds the higher drag doesn’t come into play so just feels like more power
    Hot air is less dense, so a bit less fuel before FAR limit. But power draw from other systems is also higher: AC compressor, cooling system (got to push more water through the radiator to keep engine temp acceptable).
    Finally if the cooling system is not able to keep up, for various reasons, they will derate the engine by reduced fueling as a last effort for thermal management. Not sure what it takes to get to a derate, but i assume it’s not common.
  4. Jun 16, 2021 at 11:33 AM
    #64
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    What about the knock variable?
    Higher intake air temp with a given fuel octane rating (say 87), and under high load conditions, wouldn't there be a greater possibility of knock? The ECM will pull timing in the event of course, which would reduce power as well..
    hiPSI likes this.
  5. Jun 16, 2021 at 11:36 AM
    #65
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    I remember many moons ago. At Phoenix Airport, ATC did a ground stop since temperatures were really really high. Lots of delays!
  6. Jun 16, 2021 at 12:00 PM
    #66
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Me too. I'll give this channel a whirl.
    I saw one in person out in CO Springs. Pretty cool plane. Since this thread is already sideways here's some pics I took.
    Turbo from a P47! At the very bottom you can see a turbo from a semi truck to give you scale for size.
    MOC221_[QUOTED] likes this.
  7. Jun 16, 2021 at 1:19 PM
    #67
    PTMike
    PTMike Well-Known Member
    2019 Tacoma TRD Off Road 4x4
    Most recently it was like 12 moons ago. It was on the news because temps on the tarmac got up to 120°. I think it happens every year, but news is news. Much like the dust storms that happen here every year, suddenly one looks cool on the news and now my phone tells me that a dust storm is coming. My eyes do the same thing, but now my phone makes a noise.
  8. Jun 16, 2021 at 3:53 PM
    #68
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When it was 100 degrees the other day i ran the ac....i noticed an immediate loss in power...my truck ran much differently. Seems it has at least 20% more hp with the ac off.
    hiPSI likes this.
  9. Jun 16, 2021 at 3:54 PM
    #69
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    What about UFO’s?
  10. Jun 16, 2021 at 4:06 PM
    #70
    zoo truck
    None
    Wouldn't put it past our military, or the cia to put out some propaganda that were seeing all these ufo's flying around our bases and ships claiming we have some special top secret weapons aliens are interested in.
  11. Jun 16, 2021 at 4:11 PM
    #71
    rnish
    Tacoma 2nd gen
    Aliens yes if you mean: Russia, China, N Korea, Iran…
  12. Jun 16, 2021 at 4:13 PM
    #72
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Not at all. Air temperature and density have a whole lot more to do with the aerodynamic performance of the plane and engine than just simple fluid temperatures. The electric engines still require cooling anyway.
    hiPSI likes this.
  13. Jun 16, 2021 at 4:15 PM
    #73
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Well battery cooling is obvious. So is motor cooling but not as many parts to monitor as an ICE engine.
  14. Jun 16, 2021 at 4:24 PM
    #74
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    To form a carb ice you need a moisture present, not a cold temperature.
    Once I got carb ice while taxing at kbfi at 50+°f weather. If iirc, can happen up to 70°F.
    "You want your fuel warm because it vaporizes easier as the temp increases, to a point. You don't want vapor lock."
    Vapor lock is eliminated on fuel injectors system with submerged fuel pumps.
    charliehex[QUOTED] likes this.
  15. Jun 16, 2021 at 4:55 PM
    #75
    charliehex
    charliehex I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
    Thanks for the info. I’ll add it to my tool kit.
    hiPSI likes this.
  16. Jun 16, 2021 at 5:33 PM
    #76
    Tripod1404
    Tripod1404 Annihilator tripod
    It is cold air intakes and higher octane fuel. Aliens are after that 0.5% uplift for their spaceships.
  17. Jun 16, 2021 at 6:45 PM
    #77
    I.eat.tacos
    Steve Rogers
    '18 TRD 4x4 Sport
    I thought they wanted the snorkel. You know? Traveling though the asteroid belts sucking in little meteorites can be harmful to their propulsion unit.
  18. Jun 17, 2021 at 1:50 AM
    #78
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    Definitely not a myth but it has a bigger effect on turbocharged machines since the turbos love cold dense air. Dyno a car on a cold day at low elevation versus on a hot summer day at high elevation and the horsepower numbers will speak for themselves.
  19. Jun 17, 2021 at 4:43 PM
    #79
    mgmikeds
    mgmikeds Member
    "Just out for a rip are ya, bud?"
    landphil[QUOTED] likes this.
  20. Jun 17, 2021 at 7:26 PM
    #80
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Air Temperature and altitude have a lot in common with NA IC engine performance. Ask this question in Denver (Or better, Leadville ) On a 100 degree day.
    I saw that Salt Lake had high 90s and 1% relative humidity the other day. Extreme!
