Heat and Shop Tools
Discussion in 'Garage / Workshop' started by AZBMXDAD, Aug 1, 2025.
  1. Aug 1, 2025 at 10:26 AM
    AZBMXDAD
    AZBMXDAD [OP] Sorry I can't, my son has BMX
    Gilbert, AZ
    I live in a suburb or Phoenix and to say summers are hot are an understatement. My shop is in my garage and I am wondering about the heat and the belts on my drill press and band saw. Is there something I should be doing to maintain those belts, I know the heat has to take an extra toll on them.
  2. Aug 1, 2025 at 10:50 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't worry about it, belts on engines live in much higher temps than a garage.
    I've never had to replace a belt on any piece of shop equipment other than a few things that were 30-40 years old.
    AZBMXDAD[OP] likes this.
  3. Aug 1, 2025 at 11:54 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I live in PHX. The "convective" heat from 115 degrees is probably less destructive than "conductive" heat from metal-to-belt friction.
    But the heat does melt the mounting tale used to hold the weight of a dashcam to a surface. So I leave the mount in place and unattach the dashcam (my NextBase 622 does that ... one reason I like the design) when the truck is not in use.
  4. Aug 1, 2025 at 12:01 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Surprised that you don’t have A/C in your shop in Phoenix.
  5. Aug 1, 2025 at 12:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Central CA, and I've got belts on my bandsaw and drill press.
    Everything is just fine and I see no need to worry about them.
  6. Aug 1, 2025 at 2:15 PM
    AZBMXDAD
    Gilbert, AZ
    Thank you all for the replies
  7. Aug 4, 2025 at 5:40 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Id worry more about your lights if you work in an unisulated place. They dont like the 100 degree summers and the -10 deg winters
