Heat...and then No heat...then Heat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NC2001Tacoma, Dec 5, 2020.
  1. Dec 5, 2020 at 2:55 PM
    NC2001Tacoma
    NC2001Tacoma [OP] Well-Known Member
    Not sure what the problem is,but the heat will work and then it gets cool. I mess with the dial and the heat come back. I figure it's the air mix servo that opens/closes the flap depending on which temp the dial is on. I replaced that part and it still does it.
    Any ideas as to what else it might be?
  2. Dec 5, 2020 at 3:48 PM
    codosa
    codosa Rambler
    Collon
    Maui, Hawaii
    2015 Black Access Cab 4x4
    2001 Black Ext.Cab SR5 4x4 -RIP
  3. Dec 5, 2020 at 4:24 PM
    NC2001Tacoma
  4. Dec 5, 2020 at 4:48 PM
    Indy
    Indy Master of all I survey.
    Check your coolant level.
    COMAtized99 and weefek like this.
  5. Dec 5, 2020 at 5:24 PM
    NC2001Tacoma
    I will.
  6. Dec 5, 2020 at 7:45 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Probably Fried harness and plug at the heater motor. Crawl under and look at where the heater motor under the passenger side dash plugs in. Same issue here. I found the plastic all melted. Not sure what the fix is aside from a new harness and motor
  7. Dec 8, 2020 at 4:12 PM
    NC2001Tacoma
    Ill check.
  8. Dec 8, 2020 at 4:13 PM
    NC2001Tacoma
    Coolant was ok.
  9. Jan 20, 2021 at 7:26 PM
    NC2001Tacoma
    Ive not had time to check things for a while, but I did notice today that with the air on High, I hear a slight whistle and then there is no heat. If I keep turning the air on and off until I don't hear that whistle, then the heat works. Is this anything or just a coincidence?
  10. Jan 20, 2021 at 7:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Can you move the door manually to hot and cold with the actuator removed.
  11. Jan 20, 2021 at 7:32 PM
    NC2001Tacoma
    I haven't tried, but I will tomorrow. What would it be if it did or did not open? Could the door not be opening all the way?
  12. Jan 20, 2021 at 7:36 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If the door is binding it's either broken, something fell down the vents and got stuck in it, or the HVAC housing it sits in is warped. I believe there is also a heater control valve on one of the heater hoses, you need to check that for proper operation too.
  13. Jan 20, 2021 at 7:47 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  14. Jan 24, 2021 at 1:41 PM
    NC2001Tacoma
    Finally got under the dash and checked wires,plugs,etc and found nothing that looked like it wasn't working correctly,UNTIL I decided to remove the cable that moves the mechanism that the servo goes to,that also runs to the valve under the hood.
    After I unhooked both ends and tried to pull on the cable,there was alot of resistance. I sprayed some teflon on the cable and let it run down the plastic tube the cable was in and it began moving smoothly. I then hooked things back up and the Heat was back and it was way hotter than usual. Maybe the resistance wasn't allowing the cable to engage either way enough. I'm not sure if this is actually the issue or not,but as of now,the truck has been running for around 4 hrs and the heat is still working. I'll give it a week or two to see what happens an update the outcome. Thanks for all the info.
    Dm93 and CraigF like this.
  15. Feb 18, 2021 at 4:23 PM
    NC2001Tacoma
    Well,things were fine for a few weeks and then the issue come back. Not sure what else to check.
  16. Feb 18, 2021 at 6:25 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    heat. no heat. heat.
    Sounds like my wife is in control of the thermostat.
    Xperivent and hogeyphenogey like this.
  17. Feb 18, 2021 at 7:31 PM
    Black DOG Lila
    Virginia
    Blend door actuator
  18. Feb 18, 2021 at 7:47 PM
    NC2001Tacoma
    I already replaced the one underneath on passengers side. Is that the one you're talking about?
  19. Feb 18, 2021 at 7:51 PM
    Black DOG Lila
    Virginia
    It's above the HVAC box in middle
  20. Feb 18, 2021 at 8:04 PM
    NC2001Tacoma
    Ok.Ill check it when I get a chance.
