Heat at floor, not at defroster, blower works on all speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icarus II, Feb 11, 2024.
  1. Feb 11, 2024 at 11:04 AM
    Icarus II
    Icarus II [OP] Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    2007 Prerunner:
    As the title says, there’s no heat at the defroster, but there is heat at the floor in all three positions where the floor is an outlet. Seems like it may be a door issue. Your thoughts or experiences?
  2. Feb 11, 2024 at 11:24 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree it is more than likely a Mode Servo issue. Here are the locations of the servo motors access them through the glove box opening with glove box removed.
    Part # 87106-04050 should be the part number for the servo motor assembly.
  3. Feb 11, 2024 at 11:33 AM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Thanks, I’ll get a look when I can.
    I just checked the coolant level and it seems good. Also, the hot isn’t as hot as I remember.
  4. Feb 11, 2024 at 12:04 PM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Just checked the servo, moves to 5 different positions easily. Crap!
    Sounds like an internal door issue and sounds like I need to have the dash pulled.
  5. Feb 11, 2024 at 1:51 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You can remove the servo and position it by hand and see if that works. The gears could be broken in the servo.
    TnShooter likes this.
  6. Feb 11, 2024 at 3:29 PM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    I’ll try that, thanks.
    Jimmyh[QUOTED] likes this.
  7. Feb 12, 2024 at 11:32 AM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Trying to remove the passenger side duct but can’t get the top clip to release. Any suggestions?
  8. Feb 13, 2024 at 9:42 AM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    [​IMG]Anyone have more picture of this duct? I can get 1/2 off, but I can't get it to release from the HVAC unit to get to the servo behind it.
  9. Feb 13, 2024 at 10:09 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Extra Hard Taco likes this.
  10. Feb 13, 2024 at 10:31 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I replaced mine a few months ago with a Dorman from Anal Zone. I wanna say they’re 5mm screws.
    Jimmyh likes this.
  11. Feb 13, 2024 at 11:20 AM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    @Jimmyh, I need to get to the lower one, 87106-04060.
    I can feel it clicking, so I think either the door is hung up or the gears inside the servo are stripped.
  12. Feb 13, 2024 at 11:59 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is the mixing servo to blend hot and cold air and should be easy to get to with the duct out of the way. If it is clicking then the drive gear is more than likely damaged.
    As for the duct I just grabbed it and wiggled it hard and it came off and snapped back on. Its been a while since I did this. You mileage may vary, I might have just been lucky.
  13. Feb 13, 2024 at 4:53 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I just went and took mine off, I just unhooked the top latch, gave it a little wiggle, and it popped right off. A little finiggleing and it's out.
    Jimmyh likes this.
  14. Feb 13, 2024 at 5:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That's what I did. LOL "A little finiggleing and it's out."
  15. Feb 14, 2024 at 10:06 AM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    @Jimmyh @Dm93
    Finally got the duct off. After popping the clip at the top, the right would swing free. The left would not come loose. With the front side of the duct off, I was able to grab the left side with a pair of pliers and one good tug.
    I closed the blend door by hand and I have heat until the new servo arrives.
    I'll post pictures later.
    Jimmyh likes this.
  16. Feb 14, 2024 at 11:14 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Good you got it!
    Best of luck to you!
