Heat from fresh air vent
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BAJAJAC, Dec 8, 2014.
  1. Dec 8, 2014 at 1:19 PM
    BAJAJAC
    BAJAJAC [OP] Active Member
    08 TACOMA 4X4
    Hey Tacoistas...08 4x4 ext.cab, v6. Just drove to do some shopping and the day dictated that I open the fresh air vent. The resulting warm air was a bit disconcerting. I have 82k on her and this has never happened to me.
    Any idea what is up with this?
    Thanks beforehand, we will be heading South to Baja right after the Xmas holiday so would like to see if you guys/gals have a clue..[​IMG]
  2. Dec 8, 2014 at 1:29 PM
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    Please clarify what you mean by disconcerting?
  3. Dec 8, 2014 at 1:36 PM
    BAJAJAC
    08 TACOMA 4X4
    The exterior air temp should come thru the vent. When it is hotter then that,
    "disconcerting" Also never happened before.
  4. Dec 8, 2014 at 1:39 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The dash heats up in the sun from the greenhouse effect, heating up the ducting etc. Thus heating up the fresh air as it flows through.
  5. Dec 8, 2014 at 1:47 PM
    BAJAJAC
    08 TACOMA 4X4
    We have a cool day in So. Ca. Big dff. I the outside temp and the vent temp. As I stated, 82k and never happened before!
  6. Dec 8, 2014 at 1:54 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    If your heat nob is turned over past cold it will blow warm air, turn the nob over to cold and it should feel more natural.
  7. Dec 8, 2014 at 2:03 PM
    BAJAJAC
    08 TACOMA 4X4
    This is my 3rd Tacoma...I know when the dial is in the correct position!!
  8. Dec 8, 2014 at 2:13 PM
    BAJAJAC
    08 TACOMA 4X4
    With y h u y a!
  9. Dec 8, 2014 at 2:33 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Beavis is on a roll!!!
  10. Dec 8, 2014 at 2:57 PM
    33yrsoftoys
    joel
    mid Michigan
    OPPO'D????
  11. Dec 8, 2014 at 5:11 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Yes, for about 2 minutes. Not all day.
