Heat Gun Fender Flare Trick
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mississippi Taco, Jul 29, 2014.
  1. Jul 29, 2014 at 9:03 AM
    Mississippi Taco
    Mississippi Taco [OP] Member
    Madison, MS
    01 TRD 4x4
    Leer
    Has anyone tried this on their flares? I see people doing this to Jeeps on YouTube and it looks like it works pretty well. Mine are completely faded out and i'm tired of using the "back to black" products every few months. Thanks!
  2. Jul 29, 2014 at 9:32 AM
    Yoda the Taco
    Yoda the Taco Well-Known Member
    Chase
    Kingsport
    Majestic White Stallion
    00 front end swap 3 inch spacer/block 01 dash swap Flux capacitor 04 center console tach cluster swap avatar-10 hyperdrive 02 door panels powerlocks/keyless entry electric fan swap 4runner seats
    I'm contemplating wether or not to take a shot at it this evening. I will say that its not quite as easy as they make it look from what I have read/heard. People who have tried it seem to all say it is hard to achieve an even look across the fender, and if it's done poorly it looks splotchy
  3. Jul 29, 2014 at 9:36 AM
    Large
    Large Red
    It will probably affect the paint
  4. Jul 29, 2014 at 9:42 AM
    Mississippi Taco
    Madison, MS
    01 TRD 4x4
    Leer
    I was planning to remove mine prior to trying this. The rubber seal between the paint and the flare wouldn't hold up so well i'd imagine. I'm wondering if a nozzle would help get better coverage and better results.
  5. Jul 29, 2014 at 9:48 AM
    TKGN1
    TKGN1 Well-Known Member
    Todd
    College Station, TX
    '01 DC TRD 4wd
    SAS on links, SC, flat bed
    I just did mine a few weekends ago, worked perfect. Pretty easy, took all of about 10 minutes to do both sides. I used a Milwaukee heat gun.
    Use just enough heat to turn it back to black, keep the heat moving and don't sit in one area too long.
  6. Jul 29, 2014 at 9:51 AM
    Yoda the Taco
    Chase
    Kingsport
    Thanks for the tip :cool: did you use a low or high setting?
  7. Jul 29, 2014 at 9:51 AM
    SuperJakeTheSnake
    SuperJakeTheSnake What is this place?
    Jacob
    Jacksonville NC
    02 Toyota Tacoma Prerunner
  8. Jul 29, 2014 at 9:55 AM
    TKGN1
    Todd
    College Station, TX
    '01 DC TRD 4wd
    High setting.
    I just watched the vid that was posted, pretty much did it the same way.
    Very simple process.
  9. Jul 29, 2014 at 11:13 AM
    low boy
    low boy 4wd Toyota Enthusiast
    Maryland
    2001 Tacoma TRD Xtra-cab
    lift, tires, wheels, some interior stuff
    sub'd
  10. Jul 29, 2014 at 12:22 PM
    Yoda the Taco
    Chase
    Kingsport
    Sweet! Thanks! :thumbsup:
  11. Jul 31, 2014 at 7:46 AM
    Yoda the Taco
    Chase
    Kingsport
    I finally gave it a shot last night on my worst flare. It came out pretty nice! :cool:
  12. Jul 31, 2014 at 8:23 AM
    Madjik_Man
    Colorado Front Range
    I just took mine off and refinished them the old fashion way.
    Clean, prep, prime, paint.
    They look brand new
  13. Jul 31, 2014 at 9:05 AM
    SuperJakeTheSnake
    Jacob
    Jacksonville NC
    This is what I'm going to do when I get around to it, the heat gun trick only lasts so long.
  14. Jul 31, 2014 at 10:08 AM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    I did it and it lasted about a month before it started to return to it being faded, so I prepped them and painted them.
    It was an easy process but like others have mentioned, keep the heat gun moving and you'll be fine.
  15. Aug 1, 2014 at 12:16 AM
    Taco truck
    Taco truck Active Member
    Andy
    SoCal
    01 limited crew cab
    I dont have this problem but has anybody try to plastidip them? I used that on the front bottom part of my bumper and it works great! Looks like new and lasts a lot longer than 1 month
  16. Aug 1, 2014 at 10:20 AM
    Yarddog
    Yarddog Member
    Vance
    Santa Clarita, CA
    Prerunner TRD Off-Road
    This got me thinking...I'm always one to use the main paint to tie everything together, so I think I'll paint mine...probably use PPG paint in the original paint code, prep with 400 grit sandpaper wet...seal with two coats of 'Bulldog' flexible additive...10% 'Bulldog' in the finish paint, two, maybe three coats of paint so as not to build that paint too much...obviously will have to remove the flairs, might be a good idea to get new OEM trim strips...just what I need, another project...
