Heat not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by mindbomb1973, Aug 27, 2007.
  1. Aug 27, 2007 at 12:19 PM
    mindbomb1973
    mindbomb1973 [OP] New Member
    Atlanta
    2001 Toyota Taco Sht. Bed
    Hello All,
    I have a 2001 Taco and the heat does not work (just tested it this weekend in 100+ weather). The air works fine and the engine does not have an overheating problem. I can take it in and get it fixed, but I'd have to pony up for a rental in the meantime. If it's a simple fix I thought I could do it myself.
    Thanks for any help and/or suggestions...
    -J
  2. Aug 27, 2007 at 2:12 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Sounds like the thermostat.....
  3. Aug 27, 2007 at 4:34 PM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    or heater core is stopped up
  4. Aug 28, 2007 at 5:59 AM
    mindbomb1973
    Atlanta
    Thanks for the suggestions...I'll replace the thermostat this week and report on status.
    - Jamie
  5. Aug 28, 2007 at 7:52 AM
    jrallan26
    Iowa
    Before replacing the thermsotat I would "flush" the complete cooling system. Then replace the thermstat. When everything is buttoned up, remember to "burp" the cooling system to rid the system of air.
    Hope this helps...
  6. Sep 2, 2007 at 10:51 AM
    jrallan26
    Iowa
    Any update???
  7. Jan 19, 2008 at 7:32 PM
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    Well, my heat is not working either!!!
    It's just about zero in Chicago right now. I just took a short trip in my truck and two weird things happened for the first time.
    (1) Heat didn't work at all
    (2) Engine reved to 2,000 RPM even after getting up to temp and then started to overheat (it's zero out!). I shut the truck off and went into home depot for about an hour, when I came back out it ran normal except for the heat still not working.
    The heat was working fine three days ago. I just had the timing belt, water pump, and thermostat changed out a few thousand miles ago. My 2001 is at 98,000 miles.
  8. Jan 19, 2008 at 7:37 PM
    jrallan26
    Iowa
    sounds like you have a "air bubble" in your cooling system. try burping the cooling system.
  9. Jan 19, 2008 at 7:55 PM
    DefyInertia
    Nate
    NorCal
    I burp the system by getting the truck up to temp and then opening the rad cap?
    Would the cold cause my thermostat to stick open? Cooling systems are a topic I know little about, sorry. How can I unstick the thermostat and why would a brand new one be having problems already?
    I just checked the weather channel...2F "feels like -15F" Is the extreme cold a contributing factor?
    Thanks!
  10. Jan 19, 2008 at 8:33 PM
    DefyInertia
    Nate
    NorCal
    Just went out and started the truck. The heat worked but I decided to burp the system anyway. I did this three times with some driving inbetween each. A small amount of coolant came out each time...much less the third time.
    So what was that shit all about? Is it the cold temps or should I be wondering if the machanic messed something up?
  11. Jan 20, 2008 at 6:42 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I would keep an eye on it, could be something as simple as a bad rad. cap, some how air got in the system. I know its cold so go indoors to look the engine over, heads, water pump, even bad hoses, as in another thread, flush the system. The heater core is on the passenger side (i think) so look for some rad. fluid, or a strong smell of it in the cab.
  12. Jan 20, 2008 at 4:51 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    the thermostat might be bad
  13. Jan 20, 2008 at 7:19 PM
    DefyInertia
    Nate
    NorCal
    Was not working again this morning...turned the truck on and off, burped the system, and it started working.
  14. Jan 20, 2008 at 7:30 PM
    jrallan26
    Iowa
    change the radiator cap, since you changed everything else.
  15. Nov 25, 2009 at 11:07 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    my heat also doesnt seem to be working 'up to par.' the temp gauge gets up to regular tempature, and the heat seems to kinda work on the first and second setting. I'm thinking flush the system. Am i on the right track? if not what else should i look for? thanks for any advice!!
  16. Nov 26, 2009 at 12:29 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I'm kinda thinking that most of you are having heater core problems, or may be some recent work done & linkage to gate valve that lets hot radiator fluid into heater core isn't hooked up or hooked up correctly, I dunno if its mechanical or electrical that controls valve but thats where I'd start looking....:cool:
  17. Nov 26, 2009 at 8:55 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    ^ Finally somebody in this thread that knows what the f he's talking about.
