Heat pump for garage -- mini split vs portable?
Discussion in 'Off-Topic Discussion' started by soggyBottom, Dec 23, 2022.
  1. Dec 23, 2022 at 1:25 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I want a heat pump for my garage. It's a 3 car garage. I don't need it to be 70f in the middle of winter but would nice not to need gloves. I'm trying to decide between a mini split and a portable unit. A cheap mini split is a couple hundred more than the portable.
    Installation is much much easier with the portable. 2x 4" holes in the garage is all I need. With the mini split, it's a little harder. Another benefit of the mini split is having it up on the wall instead of another thing piled up in the garage.
    Any advise? What else should I consider?
  2. Dec 23, 2022 at 4:39 PM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    I plan on doing a mini split in my garage, now wood shop. They are efficient to run, and don’t take up floor space.
    willee51 likes this.
  3. Dec 23, 2022 at 4:57 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    don't dismiss a through the wall heat pump.
  4. Dec 23, 2022 at 9:37 PM
    soggyBottom
    Are you talking about the ones that are usually.in hotel rooms?
  5. Dec 23, 2022 at 10:09 PM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    more or less, there are ones that can go higher on the wall like a mini-split's cassette
    less complicated than a split (no line st to run) and it's up off the floor
  6. Dec 23, 2022 at 11:23 PM
    VLTHNTR77
    VLTHNTR77 Well-Known Member
    Andrew
    Everett, WA.
    2016 Inferno TRD off-road
    RCI skid and sliders, GoodYear Ultraterrains, HID's, SCS SR8s, lots of ME-SO goodies, Diamondback HD.
    How cold does it get where you live? Heat pumps don't do too well in the lower 30 degree range.
  7. Dec 24, 2022 at 1:56 AM
    Tacoyeeyee
    Tacoyeeyee Member
    Al
    2023 SR 4x4
    My heat pump has been heating my home in sub freezing temps here in Texas during this polar event December 2022 with no problems. It’s a dual fuel system (propane backup).
    I have 3 mini splits on my shop and one for the tack room and one for the office. Make sure you get a good one I went with Mitsubishi better support from the manufacturer. The Chinese ones are throw always when they fail no parts available. It’s just their way of doing business. I’ve been in the industry for 50 years. The early heat pumps from the 80s to the early 90s were a learning curve for the manufacture’s. The first heat pump came out in 1856.
    texas angler likes this.
