Heat Pump not cooling...
Discussion in 'Garage / Workshop' started by resq330, Mar 22, 2012.
  1. Mar 22, 2012 at 4:13 PM
    resq330
    resq330 [OP] El' Capi-Tan
    Josh
    VA
    13 MGM DCSB TRD-Sport
    K&N Drop-In, Dick Cepek 'Torque' Wheels, Wet Okole Seat Covers, LED Interior
    As title says....I noticed my lines were also freezing over on front of coil inside. So I called my cousin (hvac certified for 6 yrs) and he said it was probably low on freon. So he came up yesterday and immediately saw an oil spot under the outside unit. My unit is approximately 15 years old I do believe. He said he thinks either the coil around outside unit is leaking or something else. Either way he thinks the refrigerant line has a leak and the fact that its so old and parts in unit are so costly, I should replace outside unit and inside coil. He quoted me a price for all that and labor (2.5 ton unit I think) for $2000.
    Any input would be greatly appreciated!!
  2. Mar 23, 2012 at 9:24 AM
    oldstick
    oldstick Medicare Member
    GA
    Offhand, I think that sounds like a good price for replacing both units.
    Seems like last time we replaced only the inside unit, it was at least $1200, I think more, and that was 6 or 7 years ago.
  3. Mar 24, 2012 at 9:27 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Your title says "heat pump not cooling". Are you trying to cool your house? Seems a little early for AC. If you are in fact trying to cool the house, there should be no frost on the outside unit. If there is frost on the outside unit when in AC mode, it would appear to me that the reversing valve is not being energized (stuck in heat mode).
    Probably a typo, but thought I would ask.
  4. Mar 24, 2012 at 9:28 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Trust me it's not too early for AC on the east coast.
  5. Mar 24, 2012 at 9:33 AM
    Crazyfrog
    Crazyfrog Well-Known Member
    Keith
    Monroe Ohio
    2010 TRD 4X4 DC
    OME 885's, Bilstien 5100, 2"AAL, Weathertechs, AVS visors, Access bed cover
    That's about half of the normal sale price from an actual place of business.
    At 15 years old, dont even think about fixing it.
    I would say your cousin is just covering his cost of goods, and keeping enough from the labor side for some beer money.
  6. Mar 26, 2012 at 6:58 AM
    resq330
    Josh
    VA
    Yeah, As joneill said, it's not too early on the east coast. It got 85+ in my house last week.
    I think I'm going to come out even better than I first thought.
    I was discussing all of this with my neighbor and he said he had a 4 year old Rheem outside unit that he would sell me for $300! My cousin and I went down and looked at it Friday evening! Looks like it will work! :woot:
  7. Apr 3, 2012 at 10:33 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Yep, it's been in the 80's here in GA the last few weeks with relatively high humidity. I've been running my AC, the humidity is what makes you sweat and uncomfortable.
  8. Apr 3, 2012 at 10:37 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    15 years is a good long run. the price sounds good too. I have a friend that owns an HVAC company, and he installed a 2.5 ton unit for me a couple years ago. It was about 2k.
    Money well spent.
  9. Apr 4, 2012 at 4:00 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Is he going to change out the tubing from the compressor to the A coil inside the house?
