Heat rising up around gear shift into cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jim Mann, Mar 13, 2007.
  1. Mar 13, 2007 at 5:15 PM
    Jim Mann
    Jim Mann [OP] Well-Known Member
    Is it normal for a Tacoma 4WD 5 speed to have heat rising up through the console, warming your right knee as you drive? The temp was near 80 today, and I never noticed the heat before. The plastic ring around the gear shift levers was fairly warm, and it almost felt as though the floor heat was on. Thanks in advance, Jim
  2. Mar 13, 2007 at 5:48 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Its unusual, I'd say. How are your fluid levels? Do you have a transmission cooler and is your rad fan working? If thermostatically controlled, is it coming on too late? When did you replace your transmission filter last? Were you hauling any weight before this experience? You have to consider may factors to clue in.:confused:
  3. Mar 13, 2007 at 8:14 PM
    Jim Mann
    No HD radiator or oil cooler, no towing. All of the fluids were replaced in November, about 4000 miles ago. The oil was changed again two weeks ago. The Rack and Pinion was replaced monday, and it will go back in the shop tomorrow for replacing the ball joints. I'll get them to check it out, but was just wondering if this heat was normal. This is a 5 speed, so there is no transmission filter that I am aware of. This is a recent change. Thanks, Jim
  4. Sep 2, 2017 at 11:07 AM
    ttwelder
    ttwelder Member
    ferris texas
    sr5 4wd trd
    K&n air
    check your tranfercase fluid immeadiatly......
  5. Sep 2, 2017 at 12:40 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It depends only how long of a drive mine gets so hot my foot gets warm .
    Gear shift gets very warm to the touch
    I only notice it in the summer after a few hours
    Dalandser likes this.
