Heat shield on cat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tammikm, Nov 21, 2019.
  1. Nov 21, 2019 at 12:09 PM
    tammikm
    tammikm [OP] Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    Cat I remove the heat shield that is on the cat. It’s rattling bad
  2. Nov 21, 2019 at 1:22 PM
    TheDamaso
    TheDamaso Well-Known Member
    Damaso
    Baytown TX
    98 2.7 4x4 5sp, 2014 TRD OR
    Did u try tightening first?
  3. Nov 21, 2019 at 1:27 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it is better to keep it and see if you can get under there and reattach it somehow, or replace it
    but you can take it off
    it does two things
    a) helps preventing brush fires
    b) retains heat in the cat for maximum emissions cleaning efficiency
    without it, just be aware driving or parking in the weeds, don't start a fire.
  4. Nov 21, 2019 at 1:34 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    It's been a few years, but I remember mine doing this due to the shield clamp rusting thru. Slapped a new clamp on there and it was good (rattle free) as new.
  5. Nov 21, 2019 at 2:03 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Couple of hose clamps around both ends and it'll be rattle free for years.
  6. Nov 21, 2019 at 2:38 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
  7. Nov 21, 2019 at 2:53 PM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    Hose clamp it is. Thanks
    Muddinfun likes this.
  8. Nov 21, 2019 at 3:41 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Real men airhammer it off and say “spare parts” always gets full of rocks and becomes a rattlebox
  9. Nov 21, 2019 at 3:42 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Shield is for not melting the front driveshaft grease out of the u-joints so leave it on. Notice only one on is that drivers side one. Use a small hose clamp on one end around the exhaust pipe and put 2 new bolts and nuts on the other end as it came - easy to see once you pull it off.
    Chris(NJ), tammikm[OP] and Muddinfun like this.
