Heat Shields RATTLING! Can I just take them off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by #sultanofsilver, May 30, 2019.
  1. Aug 8, 2019 at 1:26 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    My truck has none, for a long time. The studs rusted off the body mounted ones, exhaust ones were removed because of rattling. Hose clamps didn't cut it anymore.
  2. Aug 8, 2019 at 2:09 PM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    Same
  3. Aug 8, 2019 at 3:57 PM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    Hose clamped mine. No more rattle. Easy peasy
  4. Aug 8, 2019 at 7:59 PM
    Black__cat
    Black__cat Well-Known Member
    East Coast
    2014 Magnetic Grey C-Cab LB TRD Sport 4x4
    Could someone provide pictures of what exactly they're clamping down with hose clamps? I have the same issue when I hit bumps. Absolutely irritating. :help:
  5. Aug 9, 2019 at 10:22 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    I used 1 1/4" washers for the two large long flat heat shields on my 12 Tacoma. Studs were fine, just shields tore in that area. And I used two hose clamps (stainless) on my my CAT Converter so it would stop rattling which it did. Easy fix for both. No pics, sorry....
  6. Aug 11, 2019 at 2:22 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    See post #13 above. Crawl under your Tacoma and look up drivers side under the drivers seat area for an excellent view of the cat heat shield where one end clamps around the exhaust pipe with a hose clamp (big muffler clamp is overkill) and the other end uses 2 bolts/washers/nuts.
    Kolter45 likes this.
  7. Aug 11, 2019 at 8:07 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Once u refine those search skills it’s a magically thing!!
    eherlihy[QUOTED] likes this.
  8. May 27, 2021 at 7:51 AM
    dr.twowheel
    dr.twowheel New Member
    4door twowheel
    over the years and several trucks heat shields come off and dont seem to matter, Ikeep the cat converter shield because of higher heat.
  9. May 27, 2021 at 8:04 AM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Sine the hardware gets cooked, it might be a good preventative measure to pull it, use some brake lube on the threads and replace the nuts with stainless. I guess you could use a nylocks, but the plastic would probably cook. Keep the shields, keep it serviceable, kill the rattle.
  10. May 27, 2021 at 8:07 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Thread is two years old. OP hasn't been seen since July 2019. Maybe his truck caught on fire :D
    lynyrd3 and Kolter45 like this.
  11. Aug 11, 2021 at 9:01 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    mine just fell off....eroded right around the nut heads..Now to see if the nuts will come off or not. That will determine if it goes back on or not.
  12. Aug 11, 2021 at 9:41 AM
    Rusted Alloy
    Rusted Alloy Well-Known Member
    Dayton, OH
    2010 Toyota Tacoma SR5 Double Cab 4x4
    Same thing happened to a few of mine. Those studs feel pretty weak when trying to loosen the rusted nuts. I heated them up for a few seconds with a propane torch and they came right off with no problem. Then I used a washer that was bigger than the hole that had eroded to secure the heat shield back up.
  13. Aug 11, 2021 at 10:31 AM
    MSgt O
    2013 Tacoma
  14. Aug 12, 2021 at 6:25 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I just fixed me drivers side heat shield last week. It's been rattling for a long time and I'd had enough. Like others have mentioned, the holes thru the heat shield corroded and got larger than the nuts holding them in place.
    I was only able to get one of the three nuts off.
    Here's my fix. I useda large fender washer and put the nut back on the stud for the one I was able to get loose in the front. In the rear, I just used a short self-tapping sheet metal screw with a large fender washer and screwed thru the heat shield and the cab floor to secure it.
    No more rattle.
  15. Aug 19, 2021 at 10:43 AM
    #35
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    So, I appear to have the rattle coming from the 2 piece CC heat shield on my 08. I don't see any clamp on it at all. Is the clamp supposed to be at the forward and of the shield? I assume the heat shield should be clamped tight to the pipe at this point?
    Any clarification appreciated before I go ahead and throw a hose clamp on there
    Cheers
  16. Aug 19, 2021 at 11:23 AM
    #36
    muddog321
    FL
    Yes see post #26
    Hairy Taco likes this.
  17. Aug 19, 2021 at 12:22 PM
    #37
    Hairy Taco
    North of Hell
    08 TRD
    Thanks
  18. Aug 20, 2021 at 3:20 AM
    #38
    TheWabbit
    TheWabbit New Member
    2007 Red Tacoma TRD
    Factory at this time.
    My 07 hasn't had a heatshield since the frame recall was performed. I didn't find out they were missing for 2 years and my dealer didn't mention it. I haven't had any issues...yet!
    I'll just keep it as is.
  19. Aug 26, 2021 at 11:43 AM
    #39
    termyte14
    termyte14 New Member
    2006 Toyota Tacoma Access Cab
    So for those that have had the studs broken, what is the part number and how do you access it to replace them. Have 1 shield that's held on by 1 stud and a fender washer cause the other 2 studs are missing. It's still able to rattle at times though. Would love to fix it.
    Thanks
  20. Aug 27, 2021 at 6:33 AM
    #40
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Mine was rattling a few years ago. Yanked that bitch off and haven’t looked back. Although truth be told if I were routinely driving around in tall grass like in fields and whatnot I’d put them back on.
