Heated Mirrors Kit - Interest / Update Thread (pic heavy)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Up2NoGood, Jun 13, 2015.
Would You Like To Sign Up For Heated Mirrors
  1. YES
    734 vote(s)
    95.4%
  2. NO
    18 vote(s)
    2.3%
  3. TLDR
    17 vote(s)
    2.2%
  1. Sep 12, 2015 at 3:03 PM
    #461
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Nope nobody in Mass has offered to help. I am even shipping out my ECGS puller and driver set to people. And paying all shipping myself, and I couldn't get anyone to help put it in. Even after saying they could have the puller tool and driver set for free.
  2. Sep 12, 2015 at 7:42 PM
    #462
    Nielubie
    Nielubie Member
    Pete
    Chicago
    First off, great product. The whole harness was great quality and the instructions were great. Took me around 5-6hrs doing it, but if I did it again, probably 2-3hrs.
    Things to watch out for:
    - Spiders!!!!!! On both mirrors, after opening them up i had loads of spiders in both mirrors. Not sure if anyone else had that problem, but it sure was a surprise to me.
    - The torx screws under the mirror are not heavy duty, they are some kind of zinc, if you don't use the exact torx screwdriver needed and don't apply heavy pressure, you will strip the screw from the inside and basically you'll be screwed like i was.
    - I ran my switch under the AC, took me an hour to figure out that i didn't read the instructions correctly. I tried to run the hanger to the left/bottom from the AC control unit and its a tight fit and you'll never get it wired that way. If you read the instructions, you need to push the hanger to the left/top and it goes over all the tight spaces and fishes right in.
    - As the instructions state, depending which hole you are using to install the switch, you will need to cut off some sides of the switch to make it fit.
    - On the wire boot between the cab and door, i found it easier to run the zip tie from the door to the cab with the fat end first. I tried the other way from cab to door and i just couldn't get my hands in there to fish it through.
    Again, the product is a GREAT ONE. I would definitely recommend buying from Jaimes.
    K Mac likes this.
  3. Sep 13, 2015 at 10:11 AM
    #463
    Up2NoGood
    Up2NoGood [OP] Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Great review... I couldn't help but laugh when I got to your warning about the spiders lol. That's a first for me, I guess they were okay with a mobile home. All of your points are good ones. The routing for the switch connector is a bit tricky on the under the AC option.
    The way I believe you were trying I looked into when making this kit. I found it easy enough to get the coat hanger through, but it was just slightly too tight of an area to pull the actual switch connector through.
    An alternative would be to actually pull that part of the dash out, but to do it you need to pull out your center console and work your way over to the switch blanks... It was going to be a lot of work to do it that way.
    Thanks for the review and good to hear you got it installed!
  4. Sep 14, 2015 at 10:41 AM
    #464
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Hey man, I'd be happy to help you. I don't keep tabs on the thread, so I missed your original request for a hand, but Jaimes reached out to me. I'm just down the road in Oxford. I'll shoot you a PM with my contact info. Go ahead and get your order in, we'll set up a date when you have your hardware. :)
    Up2NoGood[OP] likes this.
  5. Sep 14, 2015 at 11:04 AM
    #465
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Man this is awesome I can't thank you enough. What would I owe you brother?
  6. Sep 14, 2015 at 12:13 PM
    #466
    BadDNA
    Eammon
    Cabot, VT
    Some good conversation and a six pack go a long way with me. :)
  7. Sep 14, 2015 at 1:04 PM
    #467
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Name your poison
  8. Sep 14, 2015 at 5:17 PM
    #468
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    That's an awesome thing you are doing! Always nice to see one member helping another out.
  9. Sep 14, 2015 at 5:33 PM
    #469
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yes it is, and as you said the other day. Some good karma is headed my way. Thanks James
    BadDNA likes this.
  10. Sep 14, 2015 at 6:47 PM
    #470
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    You're welcome, although I can't really take much credit. Glad to see you'll be getting help with it :thumbsup: BadDNA will practically be a pro at this after installing one of each kit type!
    Unchained 5150 likes this.
  11. Sep 14, 2015 at 6:48 PM
    #471
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    And while drinking beers
  12. Sep 14, 2015 at 6:50 PM
    #472
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Yep install is much better with a cold one on the go
  13. Sep 14, 2015 at 6:50 PM
    #473
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Or three
  14. Sep 14, 2015 at 6:51 PM
    #474
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
  15. Sep 14, 2015 at 7:26 PM
    #475
    BEERyce
    BEERyce Member
    Bryce
    2011 White Tacoma TRD Offroad DCSB
    Toytec Ultimate lift kit 16" Method Standard Wheels 285/75/R16 Goodyear Wranglers
    I installed my kit this last weekend and it went in really smoothly. Everything fits and works great, thanks Up2NoGood!
  16. Sep 14, 2015 at 9:05 PM
    #476
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Perfect, glad to hear things went well! With winter around the corner they should be coming in handy :)
  17. Sep 14, 2015 at 9:10 PM
    #477
    Dave H
    Dave H New Member
    Dave
    2014 Metallic Gray TRD Sport
    BF Goodrich All Terrain KO2 Black 16" FJ Cruser rims 30" Lower Grill Ridgid LED light bar BPF Skid Plate
    1) Left of steering
    2) 15 minutes
    3) green
    4) Canada
  18. Sep 14, 2015 at 9:14 PM
    #478
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    You got it and thanks for the order! I'll send you a PM in a sec.
  19. Sep 14, 2015 at 10:48 PM
    #479
    Juice33
    Juice33 Well-Known Member
    L.J.
    Mass
    2018 6MT Tacoma TRD Pro
    Sub'd Just finished work. I will want these.
  20. Sep 15, 2015 at 12:14 PM
    #480
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Sure thing, when you are ready just let me know what you are after
