Heated Mirrors Kit - Interest / Update Thread (pic heavy)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Up2NoGood, Jun 13, 2015.
Would You Like To Sign Up For Heated Mirrors
  1. YES
    733 vote(s)
    95.4%
  2. NO
    18 vote(s)
    2.3%
  3. TLDR
    17 vote(s)
    2.2%
  1. Sep 15, 2015 at 2:06 PM
    #481
    PeterVICEG
    PeterVICEG Well-Known Member
    Hey Jaimes, I am only just getting to the install. I am wondering how much current the mirrors draw.
    I ask as I have a house battery with a couple of circuits already routed to the cab area. For me I can easily put the mirrors on their own discrete cuircut.
    I want to properly protect things, so some advise is appreciated.
    Thanks,
    Peter
  2. Sep 15, 2015 at 2:13 PM
    #482
    Up2NoGood
    Up2NoGood [OP] Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Hey Peter,
    Both mirrors combined draw about 4.5 amps total.
    Hope that helps.
    Jaimes
  3. Sep 15, 2015 at 2:15 PM
    #483
    PeterVICEG
    Perfect!
    Thanks
  4. Sep 15, 2015 at 2:50 PM
    #484
    BennyTRD
    BennyTRD Active Member
    Sask, Canada
    '11 TRD Sport 4X4
    Glad I stumbled across this today, awesome man.
    1) Left of steering
    2) 15 minutes
    3) Green
    4) Canada
  5. Sep 15, 2015 at 3:10 PM
    #485
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    No problem at all
    Awesome thank you for the order. I'll put you up on the list and send you a PM shortly!
  6. Sep 16, 2015 at 3:03 PM
    #486
    PeterVICEG
    Done! A great kit. Instructions work well and Jaimes is a stand up guy and great to deal with.
    Recommended!
  7. Sep 16, 2015 at 3:16 PM
    #487
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Right on, you should be well prepared for winter now! Also thank you for ordering :thumbsup:
    Out of curiosity did you hook this up through your fuse panel or an aux. battery?
  8. Sep 16, 2015 at 5:21 PM
    #488
    PeterVICEG
    You made it too easy with the add a fuse. I plugged it in to the ACC spot as directed and, hey presto, heated mirrors.
    This leaves all my aux circuits for future needs.
    Peter
  9. Sep 16, 2015 at 7:57 PM
    #489
    TRDRACER
    TRDRACER Well-Known Member
    Beaverton, Oregon
    '15 TRD SPORT DCLB
    Thanks Jaimes for the great communication and fast shipping! This kit is nicely put together for an easy install.
  10. Sep 17, 2015 at 7:15 AM
    #490
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Hey Guys,
    I'm not exactly sure how this happened but on the Left of Steering option one of my instruction edits the grounding point for the mirrors reverted back to grounding in the door rather than in the cab (which is where the instructions should be showing to ground them). I'll be revising the instructions tonight to the in cab grounding point. Mostly a heads up for anyone who may be working on their install right now.
    Some of you may have already installed your kit by grounding inside the door panel. If so it's really not an issue if your mirrors are working fine. The reason I changed the ground to inside the cab is although the door ground point worked fine for most, a couple of people could not get a solid ground inside the door. If you don't have a solid ground you will know it as the mirror(s) will not properly heat up.
    Anyhow just a heads up, and I'll have the instructions changed back to the in cab grounding point tonight after work :thumbsup:
  11. Sep 17, 2015 at 12:58 PM
    #491
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    Update: We had some rain over the night so my windows and mirrors were fogged up. I think this is the first time I was excited to see my windows/mirrors fogged. Got in the truck and turned the mirrors on. I noticed it working pretty quickly. I have the 5 min. timer and by the time it shut off my mirrors were completely clear. Couldn't be more happy with this kit. Quality product and great service.
  12. Sep 17, 2015 at 3:02 PM
    #492
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Glad you guys like it! It definitely takes all of the annoyance out of fogged / frosted mirrors when you just need to push a button to clear them off
  13. Sep 17, 2015 at 3:38 PM
    #493
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Pumped for the install
  14. Sep 17, 2015 at 6:34 PM
    #494
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I'm looking forward to hearing that you are up and running :thumbsup:
  15. Sep 17, 2015 at 6:36 PM
    #495
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I've now uploaded the instructions for the Left of Steering Kit showing the most current grounding location. Not sure what happened there but its fixed now.
  16. Sep 18, 2015 at 8:59 AM
    #496
    Call0043
    Call0043 just cant leave anything stock !
    Chesapeake Va.
    baby seat, BHLM, satoshi, stubbs sliders, full OME suspension with extra leaf,black fog light mod , debagged,
    Left of steering
    5 min
    Amber
    USA
  17. Sep 18, 2015 at 9:15 AM
    #497
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Thanks for the order! I'll add you to the list right now and send over a PM in a minute.
  18. Sep 18, 2015 at 10:50 AM
    #498
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Mirror elements came today
    BadDNA likes this.
  19. Sep 18, 2015 at 10:57 AM
    #499
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    This is gonna be one of the best mods yet. Sad on a 34,000 vehicle it is not standard already
  20. Sep 18, 2015 at 12:06 PM
    #500
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Perfect. Provided tracking isn't lying to me the rest of your kit should be there Tuesday or Wednesday :thumbsup:
