Heated Mirrors Kit - Interest / Update Thread (pic heavy)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Up2NoGood, Jun 13, 2015.
Would You Like To Sign Up For Heated Mirrors
  1. YES
    735 vote(s)
    95.5%
  2. NO
    18 vote(s)
    2.3%
  3. TLDR
    17 vote(s)
    2.2%
  1. Sep 30, 2016 at 11:11 AM
    #1241
    Up2NoGood
    Up2NoGood [OP] Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    G.T. likes this.
  2. Oct 1, 2016 at 8:02 AM
    #1242
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Soooo....after tearing my interior apart I realized that the left of steering instructions have the switch placed on the bottom panel, next to the trac off button, which is occupied by my clutch start cancel button. Does anyone know if there is still sufficient wiring to use this location? It's only a few inches away, so I'm guessing there would be. My next concern is whether or not there is room for the switch up there, after I rip the rest of the dash apart. :annoyed:
  3. Oct 1, 2016 at 10:53 AM
    #1243
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    I have a dumb question. What is the trac off button used for?? :confused:
  4. Oct 1, 2016 at 10:54 AM
    #1244
    K_Matthews13
    K_Matthews13 Well-Known Member
    Kyler
    Utah
    2015 Toyota Tacoma TRD Off Road
    It turns your traction control off.
  5. Oct 1, 2016 at 4:14 PM
    #1245
    StevoNB
    NB, Canada
    Well the mirrors are installed! Turns out there are a few extra steps if you have the 6 speed, but the kit still works great. There is plenty of wire, I had a bit extra pretty much everywhere, but a few zip ties take care of that. Since the MT has no extra switch blanks on the bottom, the blank beside the fog lights must be used. This requires taking the upper dash apart, which just pops off really. The only other MT issue is threading the coat hanger through from the passenger side, since the parking brake handle and bracket are in the way when trying to locate the end to attach the wires to. Other than that, the instructions are great and the kit is very well built and designed. The install is pretty time consuming if its your first time taking all the interior panels off, but I'm excited to finally have some heated mirrors.
    Bravisimo and Up2NoGood[OP] like this.
  6. Oct 2, 2016 at 10:28 AM
    #1246
    jstanley
    jstanley Well-Known Member
    Central TX
    2013 TRD Sport 4x4 Pyrite Mica.
    OTT, OME, Dakar, Eaton rear locker, camper shell, Konig Six Shooters and 33" Wildpeak tires, Pelfreybilt front bumper and skids
    @Up2NoGood thanks for putting this post together. I've been following along with this and other posts, collecting parts to build a similar set up.
    I wasn't happy about the $70 center switch so I've been on the look-out for something else that would work. Today I found this:
    http://www.aironboard.com/online/toyota-replacement.html
    both left and right switches are available with heated mirror symbols and availability of various LED colors. Not inexpensive, but less expensive than factory Toyota switches. Hadn't seen anyone use this before so I thought I'd give you a heads up in case it's an option you want to offer in your kits, or in case there's someone else out there piecing a setup together as the budget allows.
    This is Texas so mirrors don't freeze often, but getting the condensation off is nice before heading into crazy town.
    Bravisimo likes this.
  7. Oct 2, 2016 at 7:36 PM
    #1247
    Bravisimo
    Joe
    Santa Clarita, CA
    Thanks! So would I turn it off during normal commute driving and then turn on when going on trials? I presume if thats the case, I should use it during rainy days?
  8. Oct 2, 2016 at 8:04 PM
    #1248
    K_Matthews13
    Kyler
    Utah
    Your traction control is always on. If you push the button down it brings up the traction control light on your dash (which means traction control is off under 30 mph). If you hold the trac off button for a couple seconds then it will bring up a trac off light on your dash (which means your traction control is off at any speed). I don't touch the button unless I do some pretty gnarly off roading where you don't really want traction control or want to do some drifting in the dirt or snow.
  9. Oct 3, 2016 at 5:13 PM
    #1249
    Bravisimo
    Joe
    Santa Clarita, CA
    OK thanks for clearing that up for me. :thumbsup:
  10. Oct 3, 2016 at 5:25 PM
    #1250
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't see price anywhere. Maybe I missed it. How much for Green, all in one mirror switch assembly, with a 10 minute (if that is even possible) in the US?
  11. Oct 3, 2016 at 5:33 PM
    #1251
    StevoNB
    NB, Canada
    Prices are all in the first post. You just have to read it carefully because it's so damn long.
  12. Oct 3, 2016 at 5:37 PM
    #1252
    StevoNB
    NB, Canada
    Ok just checked for you. It looks like $355 for the switch, but $35 extra for a timer and another $35 extra for illumination. I'd just stick with the left of steering or under climate control switch personally, if you have the room.
  13. Oct 3, 2016 at 6:38 PM
    #1253
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's one EXPENSIVE switch! What about the seperate switch? How much for the under the climate control switch then?
  14. Oct 4, 2016 at 1:23 AM
    #1254
    StevoNB
    NB, Canada
    Left of steering wheel is $340. Under climate controls is $360.
  15. Oct 4, 2016 at 10:03 AM
    #1255
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Thanks for the post. I had seen those when I first started up and wired up a couple of kits with them. There were a few minor complications to using them and I ultimately decided it would be better for me to stick with the OEM switches. It's certainly possible to use them though!
    Yeah the first post is definitely in need of some tidy up at this point. I just found that a lot of the same questions were being asked so I tried to include as much information as possible in the first post. The prices that @StevoNB quoted are correct (thanks) for complete kits which would be the switch, timer, harness & mirrors all shipped to your door.
    The kits are admittedly a bit on the pricey side, however that was the cost of going with OEM components which will be both high quality and perfect fit. I could have got the cost down by a decent amount going with aftermarket parts but figured the majority would want to go with the genuine Toyota approach.
  16. Oct 4, 2016 at 10:08 AM
    #1256
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    I have mine at 10min and think it's plenty. I live in fog/dew area and 5 is enough, but go to the Sierra's and 10 is more than enough on frost/snowy mornings. I think I've only hit the button one extra time but only for a few extra minutes. Petty much one and done.
  17. Oct 6, 2016 at 3:32 PM
    #1257
    soundguy88
    soundguy88 Member
    Bill
    Fitchburg, WI
    Tacoma TRD Sport 4WD
    All minor stuff: Added Heated Seats, Heated Mirrors, Added Rear View Mirror w/compass & Temp, De badged and removed or painted all chrome , Added new 6x9 speakers and dynamat to the inside of the doors
    How can I tell if I already have mirrors with heating strips. I have a 2014 TRD 4x4 Sport
    Thanks
  18. Oct 6, 2016 at 4:32 PM
    #1258
    G.T.
    G.T.
    CONUS
    It's my understanding that heated seats and mirrors were only offered from the factory for Canadian orders. And to be honest, that may have only been limited to the heated seats.
  19. Oct 6, 2016 at 4:43 PM
    #1259
    Pigpen
    Dan
    Northwest Montana
    Every once in awhile I like to toss a testimonial in here...
    We've had some really rainy weather lately, and while I was reversing down a forestry trail this morning my mirrors began fogging. With a push of a button, my mirrors were clear in about 30 seconds. So happy with this kit!
    StevoNB and Up2NoGood[OP] like this.
  20. Oct 6, 2016 at 4:43 PM
    #1260
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    If they are the original mirrors then they will just be standard with no heating strips.
    It's just the heated seats (which I do have and love!). I could never wrap my head around why you could get factory heated seats in Canada but not in the US.
