Heated Seat Switches
Discussion in '2nd Gen. Tacomas (2005-2015)' started by H0LLYW00D, Sep 16, 2010.
  1. Sep 16, 2010 at 7:03 AM
    H0LLYW00D
    H0LLYW00D [OP] Well-Known Member
    Is it possible to use the heated seat switches out of a 2010 tundra and put them in my 2009 tacoma? i want to move the seat switches to under the climate controls between the cigarette lighter and the aux power plug.
  2. Sep 18, 2010 at 12:30 AM
    H0LLYW00D
    these are the switches
  3. Sep 18, 2010 at 6:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What are you using them for?
    The tundra switch looks like its a variable setting - not on/off. So, whatever your using it for needs to have the capability of variable output (so to speak).
  4. Sep 18, 2010 at 4:15 PM
    H0LLYW00D
    Hoping to use these switches with the stock heated seats in my 09
  5. Sep 18, 2010 at 5:38 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    They would only work if your current seats have a variable heat like the Tundra...
  6. Sep 18, 2010 at 5:56 PM
    H0LLYW00D
    mine stock seats have a high / low and off.
  7. Sep 18, 2010 at 5:57 PM
    Matic
    Matic The "OFG" Baby!!!
    Richard
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    So maybe they have a mini rheostat or you could use one from the tundra?
  8. Sep 18, 2010 at 6:05 PM
    H0LLYW00D
    so gonna have to get my hands on the wiring diagrams and a switch set and see if it will work. then i can remove the switches from the center console and use the space for other custom switches is the idea (read front and rear lockers eventually).
  9. Sep 18, 2010 at 6:43 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    heated seats are just resistors varying the voltage through them is no big deal. They are not sensitive electronics by any means.
  10. Sep 19, 2010 at 5:41 AM
    Janster
    Jandy
    Lancaster, PA
    I'm confused....
    Your tacoma came with heated seats from the factory?
    If yes....then why do you need switches to operate them?
  11. Sep 19, 2010 at 6:12 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    ^^This
  12. Sep 19, 2010 at 6:22 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It seems the OP does not like the current switch location and the current switches probably would not fit in the blank locations that are in the Tacoma.
    The Tundra switches look like they would fit the OEM empty slots in the Tacoma.
    Personally, it seems it would be inconvenient to me to reach down underneath the climate controls to adjust the seat heaters. I would think in the center console near the armrest or shifter would be a better location.
  13. Sep 19, 2010 at 9:33 AM
    JKD
    JKD Well-Known Member
    Is there even an option for stock heated seats? I don't remember seeing it.
  14. Sep 19, 2010 at 9:35 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You can get the heated seats / leather in Canada , not sure about stateside .
  15. Sep 19, 2010 at 9:39 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Canada has them stock with leather option from the factory.,
    But getting a DC OR is no go.
  16. Sep 19, 2010 at 3:00 PM
    H0LLYW00D
    i was originally going to use the blanks for my aux driving and zux fog lights but cant find a stock toyota switch that i like. Trying to give it a stock look while also being custom, so i though if i can put the heated seat switches there, i can move the lights to the center console with the locker switches that ill add later. Unless somone has an idea for a good switch that will fit between the cig lighters. I am adding FJ fog switches for the facotry fogs and my backup lights, the ones with the on indicator.
  17. Sep 19, 2010 at 6:23 PM
    06dak
    Central Ohio
    Where are your switches now? Also, not all heaters are the same - usually the simpler ones ( high/low) have a simple thermostat with a high power switch, the complex ones (variable) can have low power switches with computer control. Were you to use a low power switch on a high power system, you'd fry the switch quick! My guess is you can't use the Tundra ones, but you might be able to use those simple aftermarket ones.
  18. Sep 19, 2010 at 6:29 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    post pics of your seats and switches please I have yet to see the leather package I have been looking though.
  19. Sep 19, 2010 at 6:34 PM
    H0LLYW00D
    the switches right now are on the center console beside the cup holder behind the auto transmission. ill try to get pics up later tomorrow. i could keep the switches there, would a large tacoma switch fit in the small blank slot with some trimming?
  20. Sep 19, 2010 at 7:42 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    sub'd...........:popcorn:
