Heated seat wiring help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maxpower29, Nov 6, 2016.
  1. Nov 6, 2016 at 4:37 PM
    #41
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Will do. I bought 4 seats worth so Im doing the install on the Yaris first because I dont care if that thing blows up then I will attempt it on my Tacoma. Should I also bolt or screw the relay down or just wire tie it? Everything else sounds good
    I didnt mention it before but the reason I never learned anything electrical is basically because when I was 16 I had to replace a wiper switch in my civic and somehow the wires shorted out and the whole harness melted all together and I was trying to run and fix wires all over the play. Was such a disaster I was scared to touch them again and just avoided it all until now
  2. Nov 6, 2016 at 4:45 PM
    #42
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Here, let me try....
    Oops! Sorry about that. ;)
    Up2NoGood and maxpower29[OP] like this.
  3. Nov 6, 2016 at 4:45 PM
    #43
    Clearwater Bill
    Billy
    Largo Florida
    No, you learned something. Bad things happen easily when you work on hot stuff.
    Pull the ground off your battery while futzing around to reduce your risk. I have blown many fuses thinking my steady hands could keep things apart that shouldn't be together. :anonymous:
  4. Nov 6, 2016 at 4:56 PM
    #44
    maxpower29
    Jordan
    Nova Scotia, Canada
    Nice. Hopefully this thread helps someone else eventually like me. I'll post pics when I do the installs. Cant wait to toast my ass!
  5. Nov 6, 2016 at 4:57 PM
    #45
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I think you'll find an add-a-fuse will be the easiest method to make the connection since no splicing will be needed with the add-a-fuse. Personal opinion but I'm not too crazy about the wire taps you selected since they compromise the wire and are a pain to remove. Just make sure to purchase a low profile mini if you go with the add-a-fuse.
  6. Nov 6, 2016 at 4:59 PM
    #46
    maxpower29
    Jordan
    Nova Scotia, Canada
    Where does that go? Replace the fuse for the cig lighter? Or a new one? I'll probably have to add more wire to the red too to make it that long I bet. Sounds cleaner though
  7. Nov 6, 2016 at 5:18 PM
    #47
    road2cycle
    Sonoma County, CA
    You will use the add-a-fuse in place of the inline fuse which came with your the heater. The wire with the butt splice will connect to your red wire on the harness. Attached are photos from my Tacoma.
    The add-a-fuse has locations for the original fuse and new fuse. It does matter which location those fuses are placed unless both are the same value. The diagram shows the location of the factory and new fuses. Note that this is not a low profile mini add-a-fuse.
  8. Nov 6, 2016 at 5:20 PM
    #48
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    I'm an idiot with electronic stuff too. I paid to have mine installed. Good luck OP! You can do it!!
    maxpower29[OP] likes this.
  9. Nov 6, 2016 at 6:10 PM
    #49
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ok so where exactly do I put both seats new fuse at? Replace the cig one but what about the other?
  10. Nov 6, 2016 at 6:35 PM
    #50
    road2cycle
    Sonoma County, CA
    You'll install the add-a-fuse in the cigarette/power outlet fuse location. That fuse location should be off when the truck is off and key is removed from the ignition. The photos I took were to give an example of what the add-a-fuse looks like. I used them for the bed lights and glove box lights on my truck. You only need one add-a-fuse since you'll be powering the seat heaters from a switched (i.e. not always on) power source.
  11. Nov 7, 2016 at 6:05 PM
    #51
    maxpower29
    Jordan
    Nova Scotia, Canada
    But if I have heaters for both seats don't I need two separate fuses or can they be attached to the same thing. Actually ya I forgot about that, if I was just splicing them into the cig lighter can I put both seats to the same wire?
  12. Nov 7, 2016 at 6:10 PM
    #52
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    This is all dependent on amperage. Wire size, switch rating, fuse size. If both heaters draw 17 amps together and you're on a 10 amp fuse then it will blow. Too many amps in a wire and it will melt. Your better off having everything on its own. You'll have to have a separate relay for a second heater anyway.
  13. Nov 7, 2016 at 6:12 PM
    #53
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya I have two separate harnesses for each seat. The picture I had was of just one seat. So I probably cant put them both the the same thing then......hmmm I ll have to find something else
  14. Nov 7, 2016 at 6:14 PM
    #54
    moondeath
    Pa, Gardners
    This is why it would be nice to have the heater power directly from the battery. Then you could use the cig outlet as the power to close the relays for both heaters. I'm not a fan of that relay sharing main power and relay power.
  15. Nov 7, 2016 at 6:15 PM
    #55
    maxpower29
    Jordan
    Nova Scotia, Canada
    So you think I should just run the red right to the battery?
  16. Nov 7, 2016 at 6:20 PM
    #56
    moondeath
    Pa, Gardners
    Unfortunately with that relay you would need to rewire one of the tabs. You definitely want the switched power from something when the truck turns on, like the cig lighter. But it would be nice to get the heater power from the battery.
  17. Nov 7, 2016 at 6:21 PM
    #57
    moondeath
    Pa, Gardners
    Not saying you can't use the cig lighter, just that it would be more convenient since you want to have 2 heaters. You'll just need to find another switched source that has the amperage rating suitable for the heater and whatever that circuit normally powers.
  18. Nov 7, 2016 at 8:55 PM
    #58
    road2cycle
    Sonoma County, CA
    OP, my answer a few post back was thinking your original photo was for both seats with one pad per seat. Now I get it that you have two sets of these with four pads total.
    I'm in agreement with what moondeath has posted this evening. With two sets of these it's better to run the heater element power from the battery (relay pin 30) while the relay's control signal (pin 86) can come from a switched 12V source from the fuse box behind the coin tray. Just note that two of those fuse locations are always on (doors is one of them, I can't remember the second; you don't want to use either of these) while all the others are powered once the ignition key is one of the two non-off positions.
    I suggest wiring the driver side up first, understand the connections, and then make similar connections for the passenger side. You will use a separate relay for each heater set and separate fuses for the connections to the battery. You can use the same add-a-fuse for both relay's control signal since the current draw (amps) will be fairly low. Basically make a "Y" connection at the add-a-fuse's butt splice connector with one part of the Y going to the switch then to driver relay pin 86 and the other part of the Y going to the the other switch then to passenger relay pin 86.
  19. Nov 7, 2016 at 9:26 PM
    #59
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I threw an add a fuse in where my rear right window fuse plugs in. Now my butt warmer stays powered for several minutes after I turn the key off. Or until I open the door.
  20. Nov 8, 2016 at 2:50 PM
    #60
    maxpower29
    Jordan
    Nova Scotia, Canada
    Does anyone know if there are any spots in the fuse panel that are pre wired and not used?
