Heater AC control lights stopped working
Discussion in '1st Gen. Tacomas (1995-2004)' started by reg, Nov 16, 2009.
  1. Nov 16, 2009 at 3:40 PM
    reg
    reg [OP] Member
    95 Tacoma
    Does anyone know how many bulbs light up the heater and AC panel on a 95 Tacoma? Mine stopped working the other day. The AC button still lights up as do the rest of the dash lights, but all of the lights on the temp/fan/heat position/recirculate do not work. It seems to me that's too big of an area to be illuminated by a single bulb, and it's unlikely that all the bulbs burned out on the same day, so right now I'm thinking that something came unplugged. I guess I was just wondering what I'll be getting into before I tear it apart.
    Thanks in advance for the help.
  2. Nov 16, 2009 at 3:55 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    well on an 04, theres 3 i believe. i could be wrong. ill check when i get it back tomorrow.
    it should be the same as the 95, although they did change the temp panel a bit. hmmm...
  3. Nov 16, 2009 at 6:29 PM
    apex9r
    apex9r mountain rover
    '97 4x4 2.7 5spd
    starting from scratch
    same exact thing on my '97:popcorn:
  4. Nov 17, 2009 at 2:43 PM
    reg
    reg [OP] Member
    95 Tacoma
    Has anyone replaced these lights in their truck?
  5. Nov 24, 2009 at 10:16 AM
    slawdog
    slawdog Member
    Georgia
    03 SR5
    I have. There are 3 bulbs that fit in to the control board behind the knobs. Very simple to replace. Check the board 1st. There are 2 wiring harnesses that plug into the back of the board. They maybe loose. If not the bulbs are very easy to replace. Had to get them from Toyota dealership here in town. Auto parts stores did not carry exact replacements.
  6. Nov 25, 2009 at 1:31 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I did, swap them all out for LED's they look real clean.
    On my ac control there is 2 bulbs
  7. Nov 25, 2009 at 6:35 PM
    apex9r
    '97 4x4 2.7 5spd
    are there replacement led's available or is it custom fab?
  8. Nov 25, 2009 at 7:37 PM
    oofy15354
    Dave
    Massachusetts
    custom fab as far as i no. if anyone has a kit let me know!
  9. Nov 25, 2009 at 7:39 PM
    JAG
    JAG Well-Known Member
    Give it a solid tap (with your fingers) to the face of the ac controls. In my 06 only one side would light up after I removed the stereo. If it does go out just tap it.
  10. Nov 25, 2009 at 8:01 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    On my 2000 its a straight swap. No soldering or anything, the Tach and speedos are bulb 194 and everything else is bulb 74
  11. Nov 25, 2009 at 8:05 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I wish this forum existed 5 or 6 years ago. My 97 did the same thing and the dealer charged big bucks to fix it. Don't remember exactly how much, but I got robbed.
  12. Nov 28, 2009 at 10:16 PM
    reg
    reg [OP] Member
    95 Tacoma
    I took the front off the heater/ac panel on my truck and it looked like there is only one bulb that lights every thing up. The bad part is that the parts guy at the dealer says that it's not a replaceable bulb... He say's I have to order the $67 blower motor switch to that has the bulb in it.
    Anyone have any experience with this switch? Where's the cheapest place to buy one of these online?
  13. Jun 10, 2013 at 5:55 PM
    z71bowhunter
    z71bowhunter Well-Known Member
    Randy
    Temple,Ga
    96 Tacoma Ex-Cab 4x4
    Looks to me with a little FAB work you can run some wires from another 12v source and install a bulb of a different size in the hole.I will let you guys know,,,mine is out too,and im thinking,,,,:D
