Heater/ac fan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1Bluewingolive!, Jun 22, 2022.
  1. Jun 22, 2022 at 5:17 PM
    1Bluewingolive!
    1Bluewingolive! [OP] Active Member
    2005 tacoma trd
    My ac fan stopped working. No fan period on heat or ac. My truck has 221,000 miles on it; all mine. Is there a fuse or time for a diagnostic look?
    Thanks
  2. Jun 22, 2022 at 5:21 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    ‘05 is going to be due for a replacement fan speed resistor, fan, or both. I’ve replaced them all in my ‘09, as well as the heater control panel because the connector on the back burned.
    b_r_o, Key-Rei and wilcam47 like this.
  3. Jun 22, 2022 at 8:07 PM
    1Bluewingolive!
    2005 tacoma trd
    Thanks for the help
  4. Jun 22, 2022 at 8:13 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Give the blower a couple solid hits with it on, if it takes off it's bad, if not get you a test light/meter if you don't have one and start checking powers and grounds starting at the blower motor and working back.
    TnShooter likes this.
  5. Jun 22, 2022 at 8:18 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Resistor connector also
  6. Jun 22, 2022 at 8:21 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The blower resistor isn't used when the switch is on high so if the OP has no high speed either it can't be that, not saying it can't be bad as well but it will not cause the blower not to work on high.
  7. Jun 22, 2022 at 8:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Before I pulled stuff apart, I’d try and see if it works on High speed.
    Then go with what my finds are of that test.
    The new updated plug an resistor are square.
    See it here with part # - https://www.tacomaworld.com/threads/oem-blower-motor-resistor-wiring.624320/
    @Jimmyh has the connection colors here.
    https://www.tacomaworld.com/threads/wiring-resistor-for-ac-blower.677253/#post-23827997
    If it’s the connector for the dial, I haven’t seen a pigtail assembly for it.
    You have to buy the plug and wire terminals for it.
    Page #2 post #23
    https://www.tacomaworld.com/threads/ac-control-wires-hot-melting-plastic-behind-dash.446790/
    If your dial control is melted make sure you get the correct one.
    Thanks to @Jimmyh again.
    https://www.tacomaworld.com/threads...ing-plastic-behind-dash.446790/#post-14859947
  8. Jul 11, 2022 at 1:58 PM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    my neighbor had the same problem..circulation fan operated only on high. After viewing several Youtube videos and reading this thread I recommended buying the Toyota OEM replacement resistor and wiring harness end. In the interim, I unplugged the harness to see if there was any discoloration, and also to show him what was involved in replacing the resistor and harness end. Surprisingly, when I plugged the connector back in and tried the switch, all positions worked. Bottom line is that the resistor is functioning and the one contact that was discolored is making contact again. We'll see how long this works before replacing the parts. BTW his Tacoma is a 2005 TRD Sport, and the switch problem came up recently. YMMV.
