Heater blend door stuck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bretts, Dec 24, 2017.
  1. Jan 18, 2018 at 7:54 PM
    #41
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    The fsm says, as you gradually turn the knob from max warm to max cool the vlt should increase from 4.5vdc to 0vdc.
  2. Jan 18, 2018 at 8:06 PM
    #42
    bretts
    bretts [OP] Well-Known Member
    Pasadena, TX
    98 Tacoma Regular Cab 2WD
    I tried removing the ribbon cable that connects the switch and testing and got the same results, it seems like the switch is doing nothing at all regardless of if it is connected, set to warm, or set to cool. same voltage all around... I think I'm going to put this back together and pull the original from the truck and swap them temporary and see if I get the same results... maybe I actually have TWO bad switches.
    License2Ill likes this.
  3. Jan 18, 2018 at 8:18 PM
    #43
    License2Ill
    Ian
    I'm sure it's happened before. Two faulty units.
    My buddies buddy is having an issue exactly as you're describing in his 3rd gen 4runner. But he's a dumbass and i don't feel like wasting my time trying to help him. Because unlike you, he doesn't seem to want to help him/ help himself.
  4. Jan 18, 2018 at 8:27 PM
    #44
    bretts
    Pasadena, TX
    trust me I'm a dumb ass. I don't even need to fix this because it is simple enough to open and close the mixer by hand, but mystery problems bug the shit out of me and I can't stop thinking about what the problem could actually be. :annoyed:
    silver lining.. I know a whole hell of a lot more about how the hvac in cars works now... and I'll stick with the cable driven AC systems like in my 92 corolla and my original 96 tacoma over these servo driven controls :rolleyes:
    GQ7227 and OG_Tacoma like this.
  5. Jan 19, 2018 at 8:09 AM
    #45
    TheDamaso
    TheDamaso Well-Known Member
    Damaso
    Baytown TX
    98 2.7 4x4 5sp, 2014 TRD OR
    Ayyyy this should almost be a sticky!!! I had been struggling with this problem on my 98 for almost a month! For me something is binding the cable that goes from the mixer to the heater valve outside, it just won’t budge in any direction so I disconnected it and turn the mixer by hand too but same thing it’s either really hot or cold. Also, anyone know why there could be a breeze in the passenger foot well? At highway speed my passenger can’t last more than 10 minutes without needing like a jacket to cover her feet and I’ve felt it too when she drives, it’s like FREEZING cold but I really can’t see where it comes from
  6. Jan 20, 2018 at 10:12 AM
    #46
    bretts
    Pasadena, TX
    welp.
    2.72 resistence (not 3) and 2.31v regardless of position of the temp switch. Looks like I got two bad units. Third times a charm, right?
  7. Jan 20, 2018 at 6:59 PM
    #47
    License2Ill
    Ian
    Bummer man.
  8. Feb 5, 2018 at 11:25 AM
    #48
    fortiz619
    fortiz619 yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    This whole actuator problems seems to effect most 1st gens , I’m having a similar problem with my ac (04 tacoma) my servo makes lots of noise when my ac is on , I removed it today and checked resistance according to the fsm it’s checks out , when you add voltage and move the knob to cold it’s doesnt stop and stays, it stops and moves half an inch up then goes back down until it act normal then it does it again , not sure if I should replace
  9. Feb 5, 2018 at 11:47 AM
    #49
    bretts
    Pasadena, TX
    yeah I never got mine working. Tried 2 used control panels and 1 used servo and no dice. Tried the relay as well... Tired of throwing money at it and I'm not doing the test procedure properly so I'll just open and close the damn thing by hand :p
    fortiz619 likes this.
  10. Feb 5, 2018 at 12:19 PM
    #50
    fortiz619
    Yeah I’ve been dealing with this for a while now , till this morning I decided remove the servo and check the gears for binding and check the resistance , I installed it like 10 minutes ago and no more noises and my ac is at full cold full blast ? Wtf?
  11. Feb 5, 2018 at 1:00 PM
    #51
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Try turning the temp knob back and forth about 40 times. Sometimes the potentiometer in the control unit gets dirty.
    There will be no voltage at servo motor unless it is being told to move. To measure voltage you have to be turning the knob. As soon as you stop turning it the voltage goes away.
  12. Feb 11, 2018 at 8:09 AM
    #52
    bretts
    Pasadena, TX
    I've replaced the ac panel with two others and never got pwr to the servo. tested both the original and a used servo by applying power and they arent burnt out.. just not getting pwr. Not sure what else to try.
  13. Dec 1, 2018 at 5:31 AM
    #53
    cynicalrider
    cynicalrider #NFG
    Jersey
    Subbing, my mixer has issues staying cold. It stays hot no problem, but when I switch to cold, it will go cold for a second and go back to hot. I need to turn it back and forth a bunch for it to stay cold, but there is never a pure blend, its either HOT or COLD. I hear the servo running and sounding like it's struggling too.
  14. Feb 10, 2019 at 3:02 PM
    #54
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    https://www.youtube.com/watch?v=4i-7GnTXFiY
    My truck just makes this servo buzzing noise literally every 5-10 second whether my AC/Heat is off or on. No issues staying cold or hot and everything functions fine. I assumed it was the door actuator being stuck but since everything works that seems unlikely.
  15. Feb 11, 2019 at 6:52 AM
    #55
    cynicalrider
    cynicalrider #NFG
    Jersey
    I have issues getting AC to stick open and I hear this noise when I go back and forth as well.
  16. Sep 23, 2019 at 9:07 AM
    #56
    cynicalrider
    cynicalrider #NFG
    Jersey
    Jon is the potentiometer in the knob itself? If so, will replacing the entire panel potentially fix this?
    This is my issue:
    I actually just broke my knob out of frustration so I ordered some aftermarket knobs and a whole panel from a 4runner to get green backlit buttons instead of orange. But if it will fix my *#$*&$@# AC issues too, I'll be happy. Might clean the blend door too.
    04Pre_Runner likes this.
  17. Sep 23, 2019 at 9:33 AM
    #57
    mechanicjon
    Jon
    Scottsdale Arizona
    Potentiometer is patt of the main control panel.
  18. Sep 23, 2019 at 9:42 AM
    #58
    cynicalrider
    cynicalrider #NFG
    Jersey
    Cool, so this might actually fix my issue. If not I think I will go and follow this thread for fixing the servo itself.
    https://www.tacomaworld.com/threads/air-servo-damper-no-2-possible-aftermarket-part.500522/
    *EDIT* I also assume I should be able to access this servo without removing the bezel that surrounds the AC controls I hope? So if I do go replace the AC controls, it should be a set it and forget it, and tackle the servo motor seperately? Or dig into it all at the same time?
  19. Sep 23, 2019 at 10:19 AM
    #59
    mechanicjon
    Jon
    Scottsdale Arizona
    Servo motor you access from under dash.
