Heater Blowing Cold Air
Discussion in '3rd Gen. Tacomas (2016-2023)' started by amadougrand, Oct 22, 2022.
  1. Oct 22, 2022 at 7:10 AM
    amadougrand
    amadougrand [OP] Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    Trying to find the common thread that works heat. Last night switching into 4wd the 4lo just started blinking without engaging even 4hi. Only way to stop it from blinking was to restart vehicle. Now this morning the engine temp is good, blower working and no heat coming out.
    what is the common thread that isn’t just my habit of beating on it hard?
    thanks for ideas
  2. Oct 22, 2022 at 7:14 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    hiPSI likes this.
  3. Oct 22, 2022 at 7:15 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    That was the first thing
  4. Oct 22, 2022 at 7:15 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Question is what wire did a mouse chew or what fuse blew that knocks out heater and 4wd
    hiPSI and Steves104x4 like this.
  5. Oct 22, 2022 at 8:16 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Bump for ideas. Checked almost every fuse so far
  6. Oct 22, 2022 at 8:29 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    You must work for Xfinity...
    Steves104x4[QUOTED] likes this.
  7. Oct 26, 2022 at 9:43 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Heater started working again. Odd
  8. Oct 26, 2022 at 9:58 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Heater usually blows cold if there is a coolant bubble in the heater core not allowing it to circulate hot engine coolant. It also won't put out much heat until the engine is up to temp.
    Sounds like you have some electrical issues on this thing tho man, might want to remove the electrical mods you have and/or get it checked out.
  9. Oct 26, 2022 at 11:19 AM
    KeNnETT
    KeNnETT Active Member
    2020 Cement Tacoma TRD Off-Road 4x4
    Bend door actuator is probably getting ready to go bad
  10. Oct 26, 2022 at 12:35 PM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    I was starting to think the blend door as well. 09 did the same were it was difficult to get it to switch hot/cold or from defrost to anything else. Eventually just left it hot and on defrost. Rolled windows down in the summer and shut off fan.
