Heater blows cold air :(
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TrailBum4x4, Dec 31, 2020.
  1. Dec 31, 2020 at 12:20 AM
    TrailBum4x4
    TrailBum4x4 [OP] New Member
    2020 White TRD OR 4x4
    Howdy! I was driving my truck through the mountains last night and I tried to turn on the heater but it only blew ice cold air as if the Cold AC was on, despite working two hours earlier. I am almost out of ideas of what it could be but I will list everything that I inspected to help narrow it down. Its a 2020 trd off-road for reference
    -the thermostat is solid because my operating temp is normal
    -it is not overheating either so my water pump is good.
    -all fuses under the hood and dash are normal and healthy
    -my coolant in both the radiator and reservoir is at full levels when the car is cold and also at operating temp
    -I can audibly hear the heater door in the dash open and close when I adjust the temp when the car is in accessory mode
    - both hoses coming out of the firewall on the driver's side are hot and of equal temperature when measured after the truck has been running
    -it is a 2020 so I don't think it has a heater control valve so that's not it
    - and I burped the radiator with the cap off and let it run for 15 minutes in the driveway
    I am absolutely out of ideas. Any help out there?
    Fullsendcf likes this.
  2. Dec 31, 2020 at 1:27 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Warranty!!!
  3. Dec 31, 2020 at 1:58 AM
    Fullsendcf
    Fullsendcf Well-Known Member
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    I’m in the same boat! Took a road trip up and down CA this past weekend around 1k miles. About 1 hour from my house the heater went out on me too. Inspected literally everything you listed as well. Mines a 2018 out of warranty though :/
  4. Dec 31, 2020 at 3:08 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Heater core clogged up? Usually happens when there’s too much rust.
  5. Dec 31, 2020 at 3:57 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    There's usually a bypass valve that shuts the flow of coolant to the core, when the AC is on. Wonder if that's failed shut some how.
  6. Dec 31, 2020 at 5:06 AM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    Sounds stupid, but double check to see that your ac switch isn’t on
  7. Dec 31, 2020 at 5:14 AM
    MGB
    MGB Well-Known Member
    2017 manual TRD Sport
    The plastic pipe at the back of the engine can crack and leak, repair cost is over $1000. A small crack can let air into the heater even without a visible loss of coolant. I had no heat without any visible loss of coolant so I decided to put in two containers of Subaru coolant conditioner which is actually a leak sealer. It solved my heat problem. Unfortunately, the problem showed up after my warranty expired. I also do not know how long this fix will last...
    Skydvrr likes this.
  8. Dec 31, 2020 at 5:16 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Oooo, that's another good one!
  9. Dec 31, 2020 at 6:30 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    What about critters like mice or chipmunks invading your heater core/ducts and building themselves a nest?
  10. Jan 1, 2021 at 2:31 PM
    FantasyFreak
    FantasyFreak Well-Known Member
    Fort Worth
    No Mo Taco/ Upsized
    I’ve recently ran into the same problem. I drove about an hour or so to go pick up my son, sat for about 5 min with truck running waiting on him and then when I went to head out about 5 min into the drive it was blowing cold. Glad I’m not the only one. I’m going to schedule a service appointment this week. If you get an update prior to when I do I would like to see what they say.
  11. Apr 11, 2022 at 5:55 PM
    Rude1
    Rude1 Well-Known Member
    What was the fix? My heat just went out on my 2018 with no obvious issues like the others here.
  12. Apr 12, 2022 at 10:28 AM
    Rude1
    Well after more research and a little luck, my heater issue turned out to be a stuck blend door. When I finally got it to work (moving the switch while banging the dash) there was a pretty loud clunk and the hot air was freed. I’m not sure if this will be a reoccurring thing but at least it not a coolant issue.
    Kevin11247 and Skydvrr like this.
  13. Apr 12, 2022 at 10:50 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Usually that is a sign that hot coolant is flowing and thus its a vent/blend door issue...which is usually the cause. There must be a bind somewhere.
    Skydvrr likes this.
