Heater blows cold at idle but warm when higher RPM's..??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomajaybee, Nov 11, 2014.
  1. Dec 2, 2016 at 8:03 PM
    #41
    Skier2388
    Skier2388 Active Member
    Justin
    2006 Tacoma
    Has anyone fix this problem I put a new thermostat in and I had the front and elevated on ramps i ran it up to normal temperature couple times, even let it sit for 24 hours with the radiator cap off and the coolent didn't go down so I don't think theres any air in it, exactly how stubborn is the air and should I go for the water pump the coolent is in really good shape so I'm not thinking it's a block heater core or partially blocked heater core but I'm kind of at a loss I have none of the signs that would indicate it's a head gasket
  2. Dec 19, 2016 at 5:32 PM
    #42
    Skier2388
    Justin
    2006 Tacoma
    My dealer said there no problem is there supposed to be a big difference in temp from idle to 2000 RPM??
  3. Dec 21, 2016 at 5:38 PM
    #43
    Skier2388
    Justin
    2006 Tacoma
    Please help I am at a loss, I have replaced the thermostat (with an OEM one) and flushed out the heater core, I have 2 concerns my lower radiator hose seems to never gets warm(even on long rides) and When the temperature gauge on the dash says it's up to running temperature and I have a spillproof funnel I don't see that there's any flow of the coolant like the water pump is pushing the water around is that all that's normal and my other thought is its normal for this truck like a design flaw for the 2006 model. I was thinking of replacing the water pump with an OEM one but my concern is that it won't help and it's an expensive part
  4. Dec 22, 2016 at 5:44 AM
    #44
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    What did your coolant look like? Was it rusty?
  5. Dec 22, 2016 at 5:46 AM
    #45
    Skier2388
    Justin
    2006 Tacoma
    No looked like it was brand-new. And the same came out of the heater core perfectly clean but I noticed today on my way in but my lower radiator hose was significantly cooler in my upper one I'm not sure if this is normal
  6. Dec 22, 2016 at 5:50 AM
    #46
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    I had a similar problem with another truck. I back flushed the heater core with a water hose. It blew out some built up gunk in the line. Maybe try that? Or something of the sort.
  7. Dec 22, 2016 at 5:52 AM
    #47
    Skier2388
    Justin
    2006 Tacoma
    I did that yesterday and it didn't help much at all and nothing bad came out
  8. Dec 22, 2016 at 5:57 AM
    #48
    Caltech90
    '19 TRD OR T4R
    Well the coolant coming out of the block is going to be hotter than the coolant going back in "If everything is working properly". I've seen the blades on a pump almost rusted all the way off a Chevy, over heating because there was no flow. If you can rev it and it gets hotter then you may have a flow issue. Bad pump or a clog somewhere.
  9. Dec 22, 2016 at 5:59 AM
    #49
    Skier2388
    Justin
    2006 Tacoma
    Ok thank you I'm thinking I'll replace the pump.
  10. Dec 22, 2016 at 7:57 AM
    #50
    omega supreme
    omega supreme Well-Known Member
    2011 TRD sport,lb
    None
    You have an air pocket.
  11. Dec 22, 2016 at 11:43 AM
    #51
    Skier2388
    Justin
    2006 Tacoma
    I'm pretty sure I got all the air out I used all the tricks I found online
  12. Jan 8, 2017 at 8:09 AM
    #52
    Skier2388
    Justin
    2006 Tacoma
    So I had 2 dealerships tell me there's nothing wrong. But I am still not getting very good heat at an idle, i have replaced and flushed every thing I can think of. So my question is, is it ok to put those head gasket repair in a bottle thing in the coolant system or will it clog every thing up?
  13. Jan 13, 2017 at 9:08 PM
    #53
    bcf
    bcf New Member
    Skier2388: I had exactly the same problem, it was started with idle overhead during Arizona summer time. I changed thermostat, replaced radiator, water pump, flushed few times, no help, 2 weeks ago I flushed the heater core, still not fix the problem, As I can hear boiling under hood after long drive, I start to think my car is head gasket issue. maybe I'll replace that this week to see if that fix the problem.
  14. Jan 13, 2017 at 10:41 PM
    #54
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    @bcf When you shut your truck off do you hear or see your coolant boiling in your over flow bottle? That's what mine did. Or do you see white crusty residue around your over flow bottle? Again that's what mine did. I had head gasket issues.
  15. Jan 14, 2017 at 3:42 AM
    #55
    Skier2388
    Justin
    2006 Tacoma
    Mine is not doing anything like that, the only thing I'm getting is very low heat at idle and a very thin White residue under the oil cap that's very thin and could be expected this time of year in New England so I'm still at a loss as to what to do
  16. Jan 14, 2017 at 4:04 AM
    #56
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Did you replace the water pump?
  17. Jan 14, 2017 at 4:14 AM
    #57
    Skier2388
    Justin
    2006 Tacoma
    Yes and the thermostat and flushed the heater core but I'm thinking maybe I didn't flush it out well enough
  18. Jan 14, 2017 at 4:18 AM
    #58
    Monkeybutt2000
    Have you pressure tested the radiator?
  19. Jan 14, 2017 at 4:22 AM
    #59
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Sounds like the Blend door actuator is bad
  20. Jan 14, 2017 at 4:51 AM
    #60
    Skier2388
    Justin
    2006 Tacoma
    What it change with idle I can't find anything online that suggest that
