Heater blows cold at idle but warm when higher RPM's..??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomajaybee, Nov 11, 2014.
  1. Jan 14, 2017 at 4:52 AM
    #61
    Skier2388
    Skier2388 Active Member
    Justin
    2006 Tacoma
  2. Jan 14, 2017 at 5:08 AM
    #62
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    Hi maybe if the door is electronically actuated there is a drop in voltage at idle some of these components are very picky about how much voltage they need to operate properly check battery and or charging system
  3. Jan 14, 2017 at 10:31 AM
    #63
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    One easy way to tell if its a Head Gasket Issue. Your radiator has to be full. With your truck running take your cap off of the radiator and watch for bubbles to come up to the top. This is exhaust gasses escaping thru the holes in the head gasket.
  4. Jan 14, 2017 at 10:36 AM
    #64
    01 Runner
    01 Runner Well-Known Member
    San Marcos,Texas
    (Old Man Tan) 2001 Pre-Runner
    2001 Tacoma Build (Started 03/17) Mods done- Wheels- -method nv's 16x8 4.5bs 0 o/s -Bfg a/t 285/75r16 Suspension- -king coilovers 2.5 (non resi) -total chaos uca -bilstein 5100 rear shocks -ome dakkar leaf springs Tech/Lights/Cool Mods- -HELLA lights mounted on bumper -Righid D2s mounted inside bumper -CB radio with rear tailgate mount -deck plate mod (actually worth it) Armor- -Relentless Fab “Predator” bumper Winch- WARN m8000 (steel cable) ————————————————————————— Mods to come- -rear bumper (relentless fab) -arb air rear locker -4x4 conversion (way down the road) -new exterior window trim -fender flare delete & 35’s -new tint -new headlights -full size spare tire -tire carrier/hi-lift/jerry-can mount
    I had similar issues and just kept moving my temp gauge from hot to cold until it worked. There's a little wire at the top center of your engine bay if you pop the hood. Make sure it gets tight when you switch it to heat, and loosens when back to cool. (Can't remember the name of the "door" it controls) Blend door?!
  5. Jan 14, 2017 at 10:44 AM
    #65
    Skier2388
    Justin
    2006 Tacoma
    I don't have any wires under the hood. It's call electronic In the 2006 anyways, and I have No bubbles when the caps off and it's running. I'm so lost with this.
    01 Runner likes this.
  6. Jan 14, 2017 at 10:48 AM
    #66
    MARSHBUSTER
    Jim
    Alamogordo NM
    The bubbles are constant. Your going to have to watch for a few minutes, I should have said that in the previous comment. Did you see my earlier post? When the truck is hot and you shut it off do you hear or see boiling in the overflow bottle? Or do you see white crusty material around the over bottle? Those are another good sign of a head gasket issue.
  7. Jan 14, 2017 at 10:50 AM
    #67
    Skier2388
    Justin
    2006 Tacoma
    I've let it run for a long time with the cap off, and seem thing and there's no odd sounds or stuff under the overflow cap
  8. Jan 14, 2017 at 10:53 AM
    #68
    MARSHBUSTER
    Jim
    Alamogordo NM
    My 2005 would only boil in the overflow bottle after I shut it off.
  9. Jan 14, 2017 at 7:04 PM
    #69
    Skier2388
    Justin
    2006 Tacoma
    I'll have to check that it, but I haven't seen anything like that
  10. Jan 14, 2017 at 7:36 PM
    #70
    MARSHBUSTER
    Jim
    Alamogordo NM
    I could here it boiling when I shut the truck off, I didn't even have to raise my hood
  11. Jan 14, 2017 at 7:50 PM
    #71
    basically_stock_
    basically_stock_ 3rd Shift Lurker
    Eric
    Iowa
    2009 TRD Sport, Free & Clear
    2" lift, SCS Ray 10, Falken Wildpeak's
    Sounds like a bad water pump
  12. Jan 14, 2017 at 7:58 PM
    #72
    MARSHBUSTER
    Jim
    Alamogordo NM
    It was a bad Head Gasket.
  13. Jan 15, 2017 at 11:18 AM
    #73
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    I had a Dodge Dakota years back that had substandard heat. Back flushing the heater core didn't really help. Ended up taking the hoses off the core,plugged the lower end of the core with a rubber plug. Then I poured CLR in the top outlet of the core and plugged it. Let is sit for several hours,then removed plugs and backflushed with water. Bam! Hot heat.
  14. Jan 17, 2017 at 5:38 PM
    #74
    Skier2388
    Justin
    2006 Tacoma
    It most be something like that I have done everything else
  15. Jan 22, 2017 at 9:00 AM
    #75
    Skier2388
    Justin
    2006 Tacoma
    I'm going to flush the whole system with a heavy duty cleaner and flush the heater core with CLR unless anyone has advice against this to see if it works
  16. Feb 13, 2017 at 10:54 AM
    #76
    travis2122
    travis2122 Member
    Travis
    Iowa
    06 PreRunner SR5
    Any resolution on this? I don't see one for the OP who started this thread years ago, or for Skier2388 who posted just a few weeks ago. I have the same "sloshing" sound in the dash and no heat at less than about 1500RPM. It's one of those things I've just learned to live with and just turn the fan speed down at stop signs/lights, but it would be great if we could pinpoint the cause and get a good fix for it.
  17. Feb 13, 2017 at 12:02 PM
    #77
    travis2122
    travis2122 Member
    Travis
    Iowa
    06 PreRunner SR5
    Well, now I feel a bit silly about this... I went out to have another look at things. Took the radiator cap off and even though it was cold, a fair amount of air came out under pressure. Now I've got nice hot air again at idle! Must have been something to do with some air trapped in the system, though I don't know how it got there.
  18. Feb 13, 2017 at 12:09 PM
    #78
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Read up on these forums about head gasket issues... and I hope I am wrong.
  19. Feb 13, 2017 at 1:04 PM
    #79
    travis2122
    travis2122 Member
    Travis
    Iowa
    06 PreRunner SR5
    Yeah, i gathered from reading this thread that is the path I need to go down now to see if that was the actual root cause. I'm also trying to remember if I did any work in the last few years that might have introduced some air into the system, but my memory is failing me at the moment.
  20. Feb 13, 2017 at 1:17 PM
    #80
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    The sloshing could be a clogged drain hose for A/C. Accompanied sometimes by water on the passenger floor mat. There should be a drain hose by the passenger side firewall you'll see from under the truck. The lower radiator hose being cooler then the top hose is normal. Unless your in the middle of the desert in summer.
