Heater control valve causing overheating
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacho_libre, May 26, 2022.
  1. May 26, 2022 at 5:29 PM
    tacho_libre
    tacho_libre [OP] Well-Known Member
    2010 V6 3.4 4WD AT and 1996 I4 2.7 4WD AT
    Hi all. Recently purchased a '96 4 cylinder 2.7 liter automatic 4wd. She runs fine, temperature normal, as long as I keep the cabin temp knob turned all the way hot. It doesn't matter if the cabin air is on or off, if I turn the knob from hot to cold within seconds the engine temp starts to rise. Only takes a minute or two to get in the red.
    I've searched all over TW and elsewhere, haven't found a clear connection between the heater valve being closed and the engine immediately overheating. Most posts talk about the heater not working, the AC fan being on, or other conditions that do not apply to my specific situation. When I turn the AC on it blows ice cold. When I turn the heat on it comes out hot. The only clear cause and effect is if I close the heater valve the engine overheats. If I keep the heater valve open, she runs at a normal temperature (driven an hour like that and no temp issues).
    I've already flushed the radiator twice and filled with new coolant, and the second time I had a shop burp all the air out in case I was screwing it up. Flushed and recharged the AC coolant. Installed a new water pump. What do y'all think?
  2. May 26, 2022 at 5:56 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Searched everywhere? Hehe, the solution is so simple you won't find something like this on the forums. So your heater is acting as a second radiator. Your main radiator is not able to cool the coolant so using the heater supplements heat dissipation. There are several solutions to this and they're mostly cheap.
    1, make sure you have sufficient AND proper coolant. Green 50/50 blend of coolant/water.
    2, replace the radiator cap. An old cap is so weak it can't keep the coolant from boiling. this would cause overheating.
    3, check your thermostat. it might just be bad and not opening up when it's supposed to.
    4, make sure your coolant hoses are good. if they expand too much they can't handle pressure causing the coolant to boil.
    5, make sure your fan shroud is good. If it doesn't work right, air won't pass through the radiator when stopped/parked.
    6, check your belts. a bad fan belt will keep the fan from cooling the radiator.
    7, a bad fan blade will keep the fan from cooling the radiator
    now here comes the more expensive things, luckily there's only 2.
    8, fan clutch. a bad clutch won't spin the fan blade allowing the coolant to overheat when stopped/parked.
    9, radiator might just be clogged. you can try flushing the system, it does work sometimes.
    Good luck!
    tacho_libre[OP] likes this.
  3. May 26, 2022 at 6:06 PM
    tacho_libre
    Thanks for the advice, you're probably right about the simplest solution being correct. I'll work my way down the list and see if anything sticks.
  4. May 26, 2022 at 6:11 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Feel for cool spots in the radiator where parts of the core might be plugged, if you feel cooler spots [or use a wire temp probe on the fins in different spots] then your radiator is due for replacement.
  5. May 26, 2022 at 6:18 PM
    Mrb1268
    Mrb1268 Well-Known Member
    2019 Cav Blue Tacoma DCLB TRD OR
    I can add 1 possibility to that list....I had a vehicle that I seemingly could not stop from overheating no matter what I tried and similar to yours the heater on high seemed to help.....after many weeks of trial and error it turned out to be that someone had installed a new water pump for an older year model and didn't realize the difference was the newer year/engine had been reconfigured to use a serpentine belt which made the impeller inside the water pump turn backwards.....a serpentine belt typically drives a water pump with the backside of the belt, a V-bet uses the inside or side with the v shape....I imagine it's not likely but a possibility with used vehicles......ok my brain is tired now.
    CodeSeven and tacho_libre[OP] like this.
  6. May 26, 2022 at 6:19 PM
    tacho_libre
    Ha interesting, thanks for the unique possibility.
    Mrb1268 likes this.
  7. May 26, 2022 at 6:30 PM
    Mrb1268
    :cheers:
    CodeSeven likes this.
