Heater Core Question for On Board Shower
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tweeek, Aug 14, 2013.
  1. Aug 14, 2013 at 12:30 PM
    tweeek
    tweeek [OP] Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    Hello, I am putting together parts to install a onboard hotwater shower using a heat exchanger. I will tap into the heater core hot water to go through the heat exchanger. I have 2 questions:
    1. Which line is the inlet and which is the return line from the heater core? I see the two coolant hoses going into the firewall on the drivers side and want to tap into the return line so as not to effect the efficiency of the internal heater.
    2. Does hot water flow to the heat exchanger all the time, or only when the heater is on? I know older vehicles used to flow only when the heater was on, but I have heard that many newer vehicles flow continuously regardless.
  2. Aug 14, 2013 at 3:27 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
  3. Aug 14, 2013 at 4:00 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    To answer #2, it flows all the time.
    The people I know who used the Helton and similar systems on the Tacoma have reported that they have to recirculate water in a bucket to get it to the desired temp.
    Sounds more trouble than its worth to me and it's not something I would want do, but to each his own.
    OP, have you tried posting over at www.expeditionportal.com/forum
    EDIT: A simple search here, yielded someone who cut up his hoses here:
  4. Aug 14, 2013 at 4:06 PM
    tweeek
    Victoria, BC
    I dont really want this thread to be a debate on what setup is better, but I want to accomplish a couple things with the heat exchanger
    1 carry less crap, all I will need is 2 hoses.
    2 a 12v pump piuts out way more pressure than the zodi
    3 no need to carry extra propane
  5. Aug 14, 2013 at 4:10 PM
    tweeek
    Victoria, BC
    Thanks for the reply. I am going to try and use a more efficient plate heat exchanger than the helton. If the engine is operating around 190 degreea I believe the temp should be sufficient. I know many people have had good results with the helton on other vehicles, plate exchangers are a fraction of tbe cost.
    The pictures you posted are very helpful, but from a first gen. I need to know which line is the return from the heater core.
    Thanks for answering #2. That is the answer I was hoping for.
  6. Aug 14, 2013 at 4:14 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I actually don't know about the 1st gens but the 2nd gens circulate all the time, so I've heard.
  7. Aug 14, 2013 at 4:15 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    I'm not too sure about which line is in & out, I ran mine from another coolant line coming off the engine near the oil filter.
    Here's my original post:
    Haven't got a picture of the direct engine shot. But I can get one if you like.
    But I've re-did the system to bypass the heat ex-changer when not needed. And have the pump inlet take water directly then push through the heat ex-changer.
  8. Aug 14, 2013 at 4:37 PM
    tweeek
    Victoria, BC
    Yes, this is what I am looking for. Ill have a look for the other coolant line by the oil filter.
    What heat exchanger did you use? How are you finding water temp & pressure?
  9. Aug 14, 2013 at 6:01 PM
    sytfu510
    Alex
    Bay Area
    I'll try to get a picture of my setup tomorrow. I'm using a 10 plate flat style ex-changer. Pressure seems to be okay for now, but my pump is not a 100% duty cycle so I try not to use it for too long. Temp I'm still playing around with trying to figure out how long I need the truck on for. I tested it once right after driving at full operating temp, and the water was perfect.
  10. Aug 25, 2013 at 7:07 PM
    tweeek
    Victoria, BC
    Hey, any update on this? Get your temp figured out or a picture of the setup? Cheers!
  11. Aug 25, 2013 at 10:12 PM
    sytfu510
    Alex
    Bay Area
    Hey, will get the picture tomorrow. Haven't figured out the heat yet. It's strange, seems sometimes I don't need much and other times I need to keep the truck on.
  12. Aug 31, 2013 at 7:48 PM
    tweeek
    Victoria, BC
    Im going to bump this again because I am still really trying to find out which is the inlet and which is the outlet to the heater core.
  13. Oct 11, 2013 at 11:16 PM
    skygear
    skygear                    
    What came of this?
  14. Oct 11, 2013 at 11:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    V6 with the towing package has an oil cooler in the filter base.
    V6 without towing package probably has both ports plugged.
  15. Oct 12, 2013 at 2:17 PM
    tweeek
    Victoria, BC
    I ended up tapping into the heater core as I allready had the right sized fittings. Used the shower this weekend, it works fantastic, its hot enough to burn at the hottest setting, but you can dial it to whatever temp you want with the thermostatic mixing valve. Drop a hose in the lake and have endless hot water. Something invigorating about a hot naked shower outdoors haha. Make a hot tub? Lol... I did find I have to raise the idle to about 1100 or 1200 to get the hot coolant circulating properly.
  16. Oct 12, 2013 at 2:23 PM
    tweeek
    Victoria, BC
    yjyvynet_4d0534fd087466dd452e96c03cc1453a4377b7fc.jpgu9ezagaq_1c4d915ca2b067452826c92988e6846452dbbae2.jpg
    Hard to see, but the pump is mounted below the mixing manifold
  17. Oct 12, 2013 at 2:29 PM
    tweeek
    Victoria, BC
  18. Oct 12, 2013 at 3:21 PM
    skygear
    skygear                    
    How do you prime your hose for the draw of water? a simple submersion of the whole hose in water then screw it into the truck?
  19. Oct 12, 2013 at 3:24 PM
    skygear
    skygear                    
    Oh, and how many PLATEs did you get? Looks almost like a 20 or 30 stack.
  20. Oct 13, 2013 at 2:32 PM
    tweeek
    Victoria, BC
    The pump self primes. I have a flojet pump that will prime upto 9 vertical feet. I connect a 20ft hose to a connection mouted on the bottom of my bumper and drop the other end in the lake or a water container and the pump does the rest.
    Its a 20 plate, 12" x 3". Admittedly overkill, but I read that some people attempting this on tacomas were having to recirculate the heated water and having poor results. I wanted something very efficient. Its the legnth of the heat exchanger that makes it more efficient, not the amount of plates. More plates reduces pressure drop.
    In reterospect, a smaller exchanger would probably work... I am thinking that poor performance people have seem with the small exchangers and tacomas has to do with the idle speed. Even with my large exchanger I have to raise the idle to aboht 1100 to get the engine to circulate the hot coolant, then the water is litterally scortching hot coming out of the exchanger. YMMV.....
