Heater/defroster not blowing hot air....HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rons01TRD, Sep 9, 2013.
  1. Sep 9, 2013 at 4:19 AM
    Rons01TRD
    Rons01TRD [OP] Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    On my way to work this morning there was a lot of moisture on the windshield, I usually turn the temp to hot and turn on the defroster until the fog/moisture starts to clear up, but this morning there was no heat? The thermostat is new and my water temp was normal. Radiator was flushed and refilled not that long ago. There has been some noise coming from behind the dash like an actuator cycling. Wondering if my A/C-Heat control unit is going bad? Anyone have this problem or can help with a solution.
    Thanks,
    Ron
  2. Sep 9, 2013 at 4:32 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'd check the cable that runs from the unit (located on the side near the gas pedal) to the regulator/butterfly valve/whatever-you-want-to-call-it on the opposite side of the firewall. Adjust the thermostat while the truck is running and watch to see if the cable and/or valve does its thing.
    I hope that helps because I pulled that out of my @$$, so take it FWIW haha :eek:
    Only other thing I can think of is a new heater core. :notsure:
  3. Sep 9, 2013 at 4:48 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I have the same noise here lately, people have said its the blend air actuator. When it starts to go bad it will start cycling back and forth. I need to try my heat and see if i have any. Havn't done that yet.
  4. Sep 9, 2013 at 5:38 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Thanks guys, I plan on checking everything when time permits. I'll keep this posted with steps and progress.
  5. Sep 9, 2013 at 6:08 AM
    TACO TX
    Kelly
    Denison ,Texas
    Please do since we both have the same issue, some insight as to how difficult it is to change, ect. I may look at mine one evening this week.
  6. Sep 9, 2013 at 7:10 AM
    TACO TX
    Kelly
    Denison ,Texas
  7. Sep 9, 2013 at 7:26 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I've been hearing a weird noise like that too lately, sub'd for the outcome. I haven't noticed anything else weird but I haven't had it while it was cold enough out to have the heat on either.
  8. Sep 9, 2013 at 5:44 PM
    TACO TX
    Kelly
    Denison ,Texas
    Well when i got home today i turned on all settings and everything is working fine, defrost hets hot and heater blows hot, recirculate is working and A/C gets cold. Mine has only started cycling a couple of mornings but doesnt seem to do it in the afternoon. IDk, guess i'll go on and deal with it if it completely takes a shit on me in the middle of winter on a cold morning. Just my luck!
  9. Sep 13, 2013 at 4:36 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Tomorrow I will have a chance to crawl under my dash and see if I can locate the problem. I'll post the results of my troubleshooting.
  10. Sep 13, 2013 at 4:43 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  11. Sep 13, 2013 at 8:20 AM
    rtb777
    rtb777 Member
    Rhett
    American Fork, Utah
    04 Tacoma SR5 TRD Double Cab
    3 in lift, XD Wheels, Bed light Mod
    I had the same noise behind my dash a couple years ago. When i pulled my actuator out it would just turn back and forth as if it didnt know which temp i had turned the dial to. Since then i just have taken the actuator out and have been manually changing the blend door.
  12. Sep 16, 2013 at 4:12 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    I was leaning in on the passenger side with keys in the ignition and power on and started cycling the temp. I could hear the actuator getter power but nothing was moving. I tapped the actuator with a screwdriver and it opened. I started the truck and went for a drive and it seems to be working now. I'm gonna buy an actuator and have it on have in case it goes completely out. Hope this helps to those that have the same issue.
