Heater Fan only works on high
Discussion in 'Technical Chat' started by Love My Taco, Dec 7, 2009.
  1. Dec 7, 2009 at 7:11 PM
    Love My Taco
    Love My Taco [OP] Active Member
    Justin
    Ohio
    05 TRD Sport xtra cab
    K&N CAI, 110 outlet in cab mod, ARE Cap, Yakima Racks, Stainless Bull Bar, tailgate lock
    Anybody else had this problem? Heater fan only works on high setting. Not sure if it's the fan itself or maybe dirty contacts or something on the dial itself. Thanks in advance.
    :confused:
  2. Dec 8, 2009 at 7:16 AM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    i had this happen in a 1990 toyota pickup.
    It was the blower motor resistor. Napa had the part for me.
  3. Dec 8, 2009 at 7:20 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I agree. That problem is almost always the resistor.
  4. Dec 8, 2009 at 7:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^what they said^
    Here are the pages from the FSM regarding the resistor
  5. Dec 8, 2009 at 1:06 PM
    lizard1
    lizard1 Well-Known Member
    Tucson
    Desert Sand Mica/4x4 off road w/lock rear
    Leer cap, rear TSB, BFG All Terrains 10 ply 265/75/16, mud flap trim, black badges, AFE filter, 3" Toytec lift, 884 OME coils, add - leaf, Bilstein 5100 all around
    It's the resistor. Mine went out a few months ago. A/C only blew on high setting. Truck was under warranty at the time - no charge. Otherwise, it's a quick job - maybe a DIY.
  6. Dec 8, 2009 at 5:31 PM
    Love My Taco
    Justin
    Ohio
    Cool. I'll try to get to it this weekend if I can fit it in between football and beer drinking. Thanks.
  7. Dec 24, 2009 at 12:01 PM
    Love My Taco
    Justin
    Ohio
    Thanks for the tips guys. Got the new resistor pack, put it in last weekend. It worked for about three days, and now I have the same problem again, it only works on high, and is somewhat intermittent. I don't know if the new part was faulty, or what. Anybody else had this problem repeatedly? I guess I'll see if I can return the part and try again. Oh yeah, Merry Christmas everybody!
  8. Feb 26, 2010 at 9:43 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Anyone find a fix for this... I'm having same problem now.
  9. Feb 26, 2010 at 9:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    Motor resistor
  10. Feb 26, 2010 at 2:13 PM
    Love My Taco
    Justin
    Ohio
    after I put the new resistor pack in, it worked for a while, then caput. Then one day my buddy was riding shotgun, and went to get something out of his pocket, pushing his foot up in that area under the dash, and low and behold the heater fan kicks on! So it turns out mine was a bad connection on the wiring harness that goes into(or right next to) the resistor pack. Haven't fixed it yet, but you may want to turn your fan on any setting but high, and reach under there and wiggle it.
    Lumberjackcoma likes this.
  11. Aug 12, 2010 at 3:59 PM
    Mr Goodwrench
    Mr Goodwrench Member
    Same problem... high speed only. Because of this thread I found the fan resistor block easy and took it out.... On the resistor block there is a spring loaded contact that is kept closed by solder. When it heats up the solder melts and the contact opens. You can fix it by holding the contact closed and resoldering it. Did that and fan works on all speeds. I think my drain hole is plugged and the condensate water collects inside the plenum (Where the resistor block lives) The water shorts it out and the contact opens. Really easy fix!!!!!!
    Dennis
  12. Dec 27, 2013 at 10:38 AM
    se2schul
    se2schul Member
    Ottawa, ON, Canada
    2006 TRD Off Road
    Had the same problem.
    Searched TW and found this thread.
    In my case, it was a bad connection. I was able to scrape the connector a bit, then wiggle the connector onto the resistor.
    Works fine now!!
    TW saves me money with an easy fix, yet again!
    DistortedAxis likes this.
  13. Dec 27, 2013 at 11:27 AM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    Why necro bumb a dead thread?
  14. Feb 6, 2014 at 8:43 PM
    bowhunter1994
    bowhunter1994 Active Member
    Where is this resistor you all are speaking off??
  15. Feb 6, 2014 at 8:50 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    There is a thread on here about it . But it's on the passenger side under the glove box.
  16. Dec 22, 2016 at 5:51 AM
    DistortedAxis
    DistortedAxis Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
    Bumping an old thread...
    Im having this issue. Blower fan ONLY works on high. Other speeds, nothing.
    I replaced the resistor and it worked for 1 week. Then stopped again. I've checked the connections and nothing. I bought a new resistor again and installed it. Everything is working....
    Just wondering if anyone has a picture of the connections that everyone is referring to?
    Also, any other input on the debacle?
  17. Dec 23, 2016 at 12:44 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just curious where all these bad resistors are coming from.
    These are cheap enough I just use the Toyota ones .
    Trying to use used ones always fails they break on the install or soon after.
  18. Dec 29, 2016 at 9:47 AM
    possum77
    possum77 Member
    South Texas
    These are what's causing my fan to stop. That's 2 times. And as you can see it's always the same wire connection. I did away with the plug and just use slip on connectors now. Still the same problem but longer time in between changing it out and only 1 connector to change
