Heater not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TurboGT, Apr 17, 2017.
  1. Apr 17, 2017 at 9:59 AM
    TurboGT
    TurboGT [OP] Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    About a week ago, my heater system just stopped working... not the fan speed resistor (I've tested the resistor and the local dealership was nice enough to pop in a brand new one before I bought it to make sure). I've also pulled the fuses & relays in the engine fuse box and confirmed that they're working as well.
    Anyone have any thoughts as to where to start looking for the problem?
    EDIT 4-20: a 50a fuse under the hood was blown, and the wires going into the motor had melted the insulation off. Replace the fuse, rewrapped the wires, and the fuse blew again. Pulled the blower motor out, took it in the house and connected it up to a 9.6v dewalt battery, and the blower at least started spinning.
    4-25: replaced the leads & connector for the blower motor, but still blowing fuses with everything plugged in, save for the motor. As soon as the parts store gets more fuses in, I'll see how things work without the resistor plugged in
  2. Apr 17, 2017 at 10:01 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Look at the harness where it plugs into the blower motor they melt sometimes.
  3. Apr 20, 2017 at 6:59 PM
    TurboGT
    Gabe
    Portland
    Updated OP, anyone with thoughts on where to go from here should speak up :)
  4. Apr 21, 2017 at 4:45 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  5. Apr 25, 2017 at 9:18 AM
    TurboGT
    Gabe
    Portland
    @Jimmyh that's my next thought... the current harness only has a slight bit of browning, and the wires and terminals are good. I've replaced that resistor a few times and I feel like the brown spot on the harness is from a previous replacement.
    Here's to hoping that AutoZone will take the heater motor back if the problem turns out to be the resistor
  6. Apr 25, 2017 at 9:20 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    subd: for final fix.
