Heater not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gale, Aug 29, 2020.
  1. Sep 1, 2020 at 2:51 PM
    Gale
    Gale [OP] Member
    2005 Tacoma 4x4
    Barely a trace in the radiator cap.
  2. Sep 1, 2020 at 2:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  3. Sep 1, 2020 at 3:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When looking into the radiator you don’t see any fluid?
    That’s not good.
    I‘m hoping the best for you buddy, but this isn’t looking good for you.
    wilcam47 likes this.
  4. Sep 1, 2020 at 4:41 PM
    Gale
    Gale [OP] Member
    2005 Tacoma 4x4
    Checked the oil cap and dipstick. Both are clean with no smell. Started the truck and no white smoke from the tail pipe. Radiator took approximately 0.5L to fill. Thinking my next steps will be a compression test for the gasket and a pressure test for the coolant system. Any thoughts?
  5. Sep 1, 2020 at 4:51 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Did I miss anyone mentioning a sticky or stuck thermostat. Cooling systems are quite simple with very few parts. Thermostats are probably the most common cause.
  6. Sep 1, 2020 at 4:53 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Sounds reasonable. Spark plug color may already indicate a head gasket failure. They should be tan at the base of the electrode, if they look all clean they’ve been steam cleaned by coolant.
  7. Sep 1, 2020 at 4:55 PM
    TireFire
    Olympic Peninsula
    Thermostats, if they get stuck, usually get stuck open not closed. The other way round would lead to overheating right quick
    Muddinfun likes this.
  8. Sep 2, 2020 at 12:48 PM
    Gale
    Gale [OP] Member
    2005 Tacoma 4x4
    Hi guys. Thought I would give a quick update. Took the truck to my mechanic and they suspect the water pump has a slow leak. They didn't have time to take it apart, so I'll have to decide my next move. Thanks for all the advice.
    SR-71A likes this.
  9. Sep 2, 2020 at 12:49 PM
    TireFire
    Olympic Peninsula
    That would be very obvious if the WP is leaking. Lots of pink crusty stuff around the shaft?
  10. Sep 2, 2020 at 12:58 PM
    Muddinfun
    Muddinfun Well-Known Member
    If it were my truck, I would do a test for head gasket leak before spending money on a water pump. There are multiple ways to test for head gasket leak. A compression test isn’t 1 of them.
  11. Sep 2, 2020 at 1:03 PM
    koditten
    Kirk
    Central Michigan
    Soooo? After topping off the coolant, did you have good heat?
  12. Sep 2, 2020 at 1:32 PM
    Gale
    Gale [OP] Member
    2005 Tacoma 4x4
    Nothing obvious for leaks. This is the second time I had it checked for leaks by a mechanic. Good pressure both times. Plus I have gone over the truck numerous times myself. Heater actually started working before I topped off the coolant. I don't see any of the obvious signs of a blown head gasket. Had a blown gasket in my Jeep Wrangler years ago and it was very obvious. White smoke, coolant smell, lack of power, milky oil, sludge under oil cap. But I'm not seeing any of those signs. Any other ideas are certainly welcome.
    koditten likes this.
  13. Sep 2, 2020 at 1:50 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Do a pressure test on the cooling system and a leak down test on the cylinders. Wouldn't hurt to check for combustion gas in the cooling system either. Agree, that amount of coolant leaking from anywhere should be fairly obvious.
  14. Sep 2, 2020 at 2:11 PM
    Gale
    Gale [OP] Member
    2005 Tacoma 4x4
    Thanks for the ideas. Pressure test was good on the cooling system. I'll look into the other test. Anyone have an idea when the head gaskets usually go? Truck is a 4cyl with 134k miles.
  15. Sep 2, 2020 at 3:11 PM
    #35
    Muddinfun
    OOOOOOOHHH, 4 cylinder. Then a look at the plastic coolant bypass tube under the intake manifold would be worthwhile.
    Jimmyh and TnShooter like this.
  16. Sep 2, 2020 at 5:52 PM
    #36
    TnShooter
    Deogee
    STOCK
    Op, you might have gotten lucky.
    Us 6cyl. guys were sweating. Lol
    Have you crawled under the truck and looked for any leaks?
    SocalTaco15 likes this.
  17. Sep 2, 2020 at 6:47 PM
    #37
    Gale
    Gale [OP] Member
    2005 Tacoma 4x4
    I'll check the plastic coolant bypass tube tomorrow, thanks. I've crawled under my truck many times to try and find the leak, but had no luck.
    Muddinfun and TnShooter like this.
  18. Sep 2, 2020 at 8:04 PM
    #38
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is that bypass pipe, there is a replacement that is metal and requires a different gasket. The pipe is behind the intake manifold.
    Torspd, TnShooter and Muddinfun like this.
  19. Sep 13, 2020 at 7:40 AM
    #39
    Gale
    Gale [OP] Member
    2005 Tacoma 4x4
    Hi guys. Just thought I would give an update. I have a copy of the description from the mechanic. They believe the water pump has a very slow leak. The coolant system must have got low over time. When I filled up the reservoir, the system took almost all of it immediately. This explains why I lost the entire reservoir in one day, but couldn't find any obvious leaks. I will continue to monitor the coolant and get the water pump looked at as soon as possible. Thanks everyone for the help.
  20. Sep 13, 2020 at 8:53 AM
    #40
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I had to replace a water pump on my 1st Gen 2.4L Tacoma - a cousin of the 2.7L. Pump started leaking at 65K. If your water pump is leaking, you should be able to see the leak.
    TireFire likes this.
