Heater only works on low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UncleBenRice, Dec 5, 2017.
  1. Dec 5, 2017 at 4:38 PM
    UncleBenRice
    UncleBenRice [OP] Member
    Anthony
    Westminster Co
    2015 White TRD OR
    If this has been covered I apologize I wasn't able to find it. Today my heater started to only work on the lower two settings, the higher 2 do nothing. I saw the resistor threads but they state that it will only work on hi. Is this the same situation?
  2. Dec 5, 2017 at 4:50 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    A friend of mine has a 2007 access cab SR5 5-lug, and the HVAC system quit working altogether. It would turn on but not blow any air whatsoever. I believe it ended up being the blower motor, and I think he had it replaced when he brought his truck in for a free frame replacement. It's also possible the HVAC control itself is bad. It probably won't be cheap to buy a new one, but it is very easy for the do-it-yourselfer to remove and replace.
    I removed the control while troubleshooting a problem with the A/C in my truck last spring. It was blowing ICE COLD from the driver's side vents, cool to warm from the middle-right vent, and warm humid air from the far right vent. Luckily, it turned out my truck did not have any serious problems and just needed a recharge. However, here some pics I took while I had the HVAC control removed...
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  3. Dec 5, 2017 at 4:56 PM
    UncleBenRice
    Anthony
    Westminster Co
    2015 White TRD OR
    I figured it out. Somehow the plug came partially undone from the switch. It is working now. Thank you for your help.
    CurtB and PennSilverTaco like this.
  4. Dec 5, 2017 at 4:56 PM
    PennSilverTaco
    Charlie
    :thumbsup:
    :cheers:
