Heater Problems!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Offroadtaco, Feb 15, 2013.
  1. Feb 15, 2013 at 1:48 PM
    Offroadtaco
    Offroadtaco [OP] Active Member
    08 PreRunner SR5
    Cobra 29 LTD Classic CB Radio, Fire Stick 4ft antenna, A.R.E. Campershell, 12in sub with JBL amp, Rear bumper tow loops.
    In my 2008 tacoma, the heater runs and the fan speed can be controlled, however, the temperature cannot. I cant figure out whether it is in the relays or in the control panel. Please help. When I switch the A/C on you can hear the pump kick in but the air comming throught the vents is unchanged. Even if it runs for 5 minutes. What do I do?
  2. Feb 15, 2013 at 4:36 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    check to make sure the blend door servo motors are moving and the door in the heater box isnt broken
  3. Feb 15, 2013 at 7:26 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Or even something simple and very easy to check, like the wire has not come off of the back of the panel. You just pop it out to check. Examine the back of the connector and check for burnt wires.
  4. Feb 16, 2013 at 8:29 AM
    Offroadtaco
    08 PreRunner SR5
    all the wires are connected, ill check to see if the door is opening and closing, my guess is it is not.
