Heater shuts off if headlights are on
Discussion in '1st Gen. Tacomas (1995-2004)' started by Backcountrysledder7, Feb 11, 2021.
  1. Jun 5, 2021 at 9:35 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Any mods to electronics? Alarms, stereo, etc?
  2. Jun 5, 2021 at 9:39 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I bet it has to do with that aftermarket radio and the dimmer circuit
  3. Jun 5, 2021 at 10:50 PM
    Glamisman
    Glamisman Well-Known Member
    at the engine compartment fuse box there is a shared connector for the headlights and the heater. J9 is grey and it is a 12 position connector that uses only 4 positions. These are the ground connections for both the heater (white/black) and the headlights (red/green).
    0xDEADBEEF likes this.
  4. Jun 7, 2021 at 5:37 AM
    Backcountrysledder7
    Backcountrysledder7 [OP] Member
    Trenton
    Coeurd'Alene Idaho
    2017 white TRD TACOMA
    Nothing yet!
    Aftermarket stereo, amp and subs installed before I got the truck. Definitely a poor installation. No alarm system. I will check the dimmer circuit and those fuses and go from there!
  5. Jun 7, 2021 at 5:48 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I would start with the part where everything works when the engine is off but the key is in the "on" position, but not when the engine is running. Seems like there has to be a place in the wiring diagrams where you can find what's different about those two states and troubleshoot them one by one.
    As others said, the Toyota complete electrical diagram for your specific truck is the most useful tool for this. Good luck with the gremlins.
  6. Jun 7, 2021 at 6:36 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I'm not the best at tracking down W/H issues, but I took a look at the 2000 diagrams I have. The only thing I saw in common was ground point "IE" that is listed as "near the right hand end of the IP reinforcement bar. Basically behind or above the right hand kick panel area.
    Madjik_Man likes this.
  7. Jan 14, 2023 at 12:28 PM
    Vwsxcjthedj
    Vwsxcjthedj New Member
    1995 tacoma 4x4 2.7
    Wondering if the OP ever figured this out? I'm having the same problem with a tacoma I just bought as well.
  8. Jan 14, 2023 at 8:47 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Do you have your charging system voltage ?
    I am guessing your blower motor shuts off when your head lights are turned on??
  9. Jan 14, 2023 at 9:38 PM
    Vwsxcjthedj
    1995 tacoma 4x4 2.7
    Yup blower motor will turn off when headlights are turned on while running. Oddly enough though when the truck is off (key out) if I flick the lights on, the blower starts and headlights come on
  10. Jan 15, 2023 at 3:24 AM
    Bivouac
    Your saying with the engine off the blower motor turns on with the head lights.
    Some place you have some crossed wiring either physical damage allowing 2 positive wires to merge without shorting.
    After market wiring done rather poor.
    Both circuits may share common ground connections loose connections might be the issue.
    Most time loose connections will arc and open fuses and more circuits might be effected
    One circuit the blower motor is switched power and should not enegrize unless the ignition switch is in run.
    Head lights are switched ground
    Wish you were close I love a good challenge.
    Good luck
