Heater wont blow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RIDDICK3, Feb 1, 2014.
  1. Feb 1, 2014 at 4:14 PM
    RIDDICK3
    RIDDICK3 [OP] nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    Hello, went to start my truck this morning and noticed my heater doesn't even blow air on any setting. Has anyone else had this problem? I just replaced the resistor and still no fix. but the resistor did look different then the stock one could I have gotten the wrong part?
  2. Feb 1, 2014 at 4:29 PM
    InSight Retrofits
    InSight Retrofits Closed
    I have the same problem with my gf.
    Aftermarket parts usually look different anyway. Best thing right now is to check fuses (step 1 before replacing parts) swap the fuse too, they can blow and look fine. Step 2 take the blower out and put power to it.
    I had a local mechanic come into work and asked for a motor and resistor. I asked him if his fan still works so he could narrow down the problem and save himself time and the customer money. I took his fan, had him hold it and powered it to a battery and boom kicked on like a mule. Resistor was fine too. It was just the fuse but for some reason mechanics these days jump over the obvious "check me first" steps and go right to replacing parts.
  3. Feb 1, 2014 at 4:47 PM
    InSight Retrofits
    Step # 3 ^:rofl:
  4. Feb 1, 2014 at 5:20 PM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    The flashlight tap should be the first thing to try
    I would get my wife to kick it if she was with me
    My 2002 and 2011 trucks both had the blower suddenly stop working
    The 2002 just needed removal of crude and leaves
    The 2011 had a field mouse family living in it
    Check the easy stuff first
    Take cabin air filter out and look to see if there something keeping the fan from spinning
